Sudden drop in speed
- Re: Sudden drop in speed
20-08-2009 12:35 PM
Just over a week ago my broadband speed dropped like a lead balloon. Previously i was achieving the dizzy heights of 3mb, now all it can manage is 512k. I have run the usual diagnostics and even got the guys at plus to run some tests all to no avail. BT have always reported that my line can support 3mb up until i checked with them again last week. Now they report that I can only achieve the 512k that i'm getting.
Can anyone help me?
Thanks in advance if you can
20-08-2009 1:48 PM
Your DSL connection rate: 4544 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 2000 kbps
Actual IP throughput achieved during the test was - 298 kbps
Could this be a stuck IP Profile?
20-08-2009 1:54 PM
What does this say https://portal.plus.net/my.html?action=data_transfer_speed
Also try this speed test http://www.mybroadbandspeed.co.uk/
20-08-2009 2:03 PM
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
350
2nd one
Today 14:02 341 kbps (42.6kB/s) 288 kbps (36kB/s)
20-08-2009 2:08 PM
If you raise a ticket enclosing the BT speedtest result than Plusnet should update their system as it clearly hasn't picked up the latest profile update yet.
The question is - what caused the massive speed drop. Did someone plug a phone, Sky box, etc in without a filter
20-08-2009 2:11 PM
20-08-2009 2:12 PM
Quote from: Oldjim The question is - what caused the massive speed drop. Did someone plug a phone, Sky box, etc in without a filter
Thunderstorm? I was working at a house with an old Speedtouch broadband modem during a thunderstorm. Every time there was a nearby lightning strike, the modem lost sync.
20-08-2009 2:33 PM
Also which router are you using.
20-08-2009 2:42 PM
Here's the stats
Downstream Upstream
Data rate 4576 448
Noise margin 12.3 22.0
Output power 19.6 12.3
Attenuation 50.0 30.0
20-08-2009 3:03 PM
The bit which does concern me is the IPprofile of 2000kbps which tends to indicate that your speed didn't jump right back up again but went up over a period of time.
All you can do at this stage is check your synch speeds and noise margin at intervals over the evening.
You could try downloading DMT v 8.07 which should work with your router and use that to log the noise margin http://dmt.mhilfe.de/
This will give a lot more information about what is happening
20-08-2009 3:16 PM
I've just updated your profile.
If you reboot your router you should see an improvement in speed.
