Strange packet loss
mrcoyote
Strange packet loss
Just checked my TBB monitor and it's showing some odd packet loss which seemed to start this morning...
BTW Speed check has come up with
Download speedachieved during the test was - 35.38 Mbps
For your connection, the acceptable range of speedsis 12 Mbps-65.26 Mbps .
Additional Information:
IP Profile for your line is - 65.26 Mbps
Upload Speed
15.5 Mbps
0 Mbps 20 Mbps
Max Achievable Speed
Upload speed achieved during the test was - 15.5Mbps
We were unable to identify any performance problem with your service at this time.
It's not ideal, but I'm guessing it's to be expected given the packet loss.
Gateway hopping seems to have helped the Speedtest.net results, but the BTW are still pretty similar.
Is this something on Plusnet's network or my connection?
9 REPLIES 9
w23
Fixes: 4
Re: Strange packet loss
What is your Plusnet line profile 'Current Line Speed' here: https://portal.plus.net/my.html?action=data_transfer_speed? (requires login to member centre)
Call me 'w23'
mrcoyote
65.4Mb.  I'm sure that's been stable for at least the last month.
jelv
Fixes: 10
So what did you do around the time of your last post? Reconnect?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
mrcoyote
Looking at the graph reconnecting helped, but speeds were still pretty bad. Much better this morning though.
chrispurvey
We've noticed a few of these and are looking into this, it seems to be people connected to PCL-AG05,
Take a look a Bob's ping graph he was on the same gateway as you.
bobpullen
Fixes: 316
Quote from: chrispurvey
And it showed. Struggled to stream a YouTube video without it buffering and my line's capable of 76Mbps Huh
There's an internal problem open to look into what's happening (ref: 76792).
VileReynard
Fixes: 20
Very high lately!
See Sam Knows!
mrcoyote
In some respects, having just bought a new router, I'm glad it wasn't just me, but these types of things seem to be getting more frequent recently. Sad
bobpullen
Fixes: 316
We've since identified the fault and disabled the affected link. This isn't related to any previous problems we've experienced recently.
