Static IP inbound ports blocked
puccovelli
Re: Static IP inbound ports blocked
Yes like I said Plusnet firewall is OFF. Believe me you’re not the only one that’s puzzled. I’ve tried everything.
I need the static IP working properly or there is no point having it. I’m gonna do some final checks this morning but if it’s not working by my the time I have my cancellation chat this afternoon I see no option but to have to use a different ISP.
Fixes: 145
@puccovelli
Do you see the port forward messages when you are testing?
Can you share the >Home ->Advanced settings --> Technical log ---> Event log ?
@markhawkin
I'm not using my Hub two anymore, so can not answer the question you asked.
puccovelli
No I see nothing on the logs no matter which router I use.
markhawkin
Aspiring Champion
Fixes: 20
Does a ThinkBroadband monitor "see" the router?
I think you may need to set the Hub 2 to respond to WAN pings.
Also I assume you must be an "old" customer as static IP addresses are not available to recent sign ups.
Is this a recent setup or have you had VPN connections working in the past?
