Spring Cleaning the Portal - Suggestions for alternate tools
- Spring Cleaning the Portal - Suggestions for alter...
17-03-2008 1:07 PM
Plusnet Technology
Re: Spring Cleaning the Portal - Suggestions for alternate tools
17-03-2008 1:13 PM
Diary and Favourites come at the expense of Google Calendar and Google Toolbar.
Address Book in some form comes on my mobile coupled with with a remote sync function (which saved a shed load of time in loading my contacts to my new mobile).
17-03-2008 2:05 PM
17-03-2008 3:20 PM
and one surrgestion would it be possable to just have a paid for usage total some where on the front page so as soon as u sign in to the portal u know how much paid for usage u have left.
i know its not a great deal to go to connection settings then to usage data but it would be handy to be able to see this usage data as soon as u login.
from a happy plus net user
17-03-2008 3:25 PM
Quote from: scootie i know its not a great deal to go to connection settings then to usage data but it would be handy to be able to see this usage data as soon as u login.
We're currently looking into 'widgetising' the member centre in a similar style to iGoogle and the new bbc homepage so that everyone can customise it with exactly the information they want. It's won't happen in the next few months but most of agree that it's The Way To Go. We may even be able to fix it so that you can see your usage/billing info from the igoogle homepage without even visiting the member centre!
17-03-2008 4:21 PM
Quote from: Peter Why are you not removing the website builder link which has been unusable for years!
You can't argue with that question - For some reason my spreadsheet says "Already removed"...
Can anyone suggest a reason not to 'dissappear' that at the same time?
Ian
17-03-2008 4:35 PM
Also when was the postcode finder data last updated AND when was it last actually used?
I seem to recall it was never very good anyway so perhaps another one to remove - considering a quick google will find the info anyway (and be more up to date).
So, that just leaves MySQL admin
17-03-2008 4:45 PM
Quote from: Peter Also when was the postcode finder data last updated AND when was it last actually used?
I've used it not that long ago.
17-03-2008 4:56 PM
Ian
17-03-2008 4:56 PM
I thought we were pointing that to some third party tools ie. the help article here. Guess that never happened though. I think we should probably just build on the support content. Perhaps link to some third party WYSIWYG web apps like the one here.
17-03-2008 7:06 PM
Quote from: jelv
Me too .... although I was testing something
17-03-2008 7:51 PM
I use it too, when I can't be bothered to log into work
17-03-2008 8:37 PM
17-03-2008 9:17 PM
It gives much more detail and allows you to work out exactly which code is relevant on roads with multiple postcodes (like mine) as you can see a full list of properties - even companies in commercial locations.
17-03-2008 9:45 PM
