Speeds still around 40Mbit/sec after changing products to 80/20 Extra Fibre
- Re: Speeds still around 40Mbit/sec after changing ...
- « Previous
- 1
- 2
- Next »
Re: Speeds still around 40Mbit/sec after changing products to 80/20 Extra Fibre
01-10-2012 7:26 PM
Message 16 of 24
(557 Views)
02-10-2012 11:18 AM
It's not normally something that does take time to increase although I have seen it happen in the past. Are you using a wired or wireless connection?
Message 17 of 24
(557 Views)
02-10-2012 12:30 PM
I have a wired connection and the modem and router are both right next to the connection point.
Message 18 of 24
(557 Views)
02-10-2012 12:46 PM
Mine is on a wireless connection. Still no further change.
Message 19 of 24
(557 Views)
02-10-2012 12:48 PM
Wireless is likely to be your limiting factor, can you try a wired test?
Message 20 of 24
(557 Views)
02-10-2012 6:05 PM
what about mine???
im on the 72mbs 20mbs service and get 6o odd mbs but now only 4mbs upload.
it went upto 16mbs upload for 1 day!!!!!
Message 21 of 24
(557 Views)
02-10-2012 8:50 PM
Quote from: dvorak Wireless is likely to be your limiting factor, can you try a wired test?
Ah yes. That has improved it. It's still slightly slower than I thought I'd get but perfectly reasonable.
I've never had a connection fast enough to worry about the wireless being a limiting factor before! Though considering that my master socket is in a hard to access cupboard in the corner of the house, I should probably have thought to try this earlier. The wireless signal has to get through several doors and a wall or two. It does mean that I'm effectively limited to about 40 meg, by the sounds of things. Oh well. Still better than the 3.6 meg I was getting before.
Message 22 of 24
(557 Views)
08-10-2012 2:26 PM
Quote from: cutglass I've never had a connection fast enough to worry about the wireless being a limiting factor before! Though considering that my master socket is in a hard to access cupboard in the corner of the house, I should probably have thought to try this earlier. The wireless signal has to get through several doors and a wall or two. It does mean that I'm effectively limited to about 40 meg, by the sounds of things. Oh well. Still better than the 3.6 meg I was getting before.
As a further thought on this, is there any way round this problem that doesn't involve me stringing a lengthy ethernet cable through my house?
Would a different router improve matters? What about a wireless repeater? Something else I've not thought ot?
Message 23 of 24
(557 Views)
08-10-2012 8:42 PM
In my personal opinion wired connections are always the best way to go and guarantee you a good quality connection, you could use some cable management to disguise your cable or run it underneath your carpet (depending on the layout of your house).
If you do want to stick with wireless though a repeater is a good idea as I dont think your problem can be fixed just by getting a better router.
Message 24 of 24
(557 Views)
- « Previous
- 1
- 2
- Next »
