Speeds slowing by the day
- Speeds slowing by the day
Re: Speeds slowing by the day
19-05-2013 11:13 AM
I do note that the DS Attenuation has changed again - so suspected bad joint, but more evidence is desirable. Intermittent faults are usually a real .... to find and often do not always show up on line tests.
19-05-2013 1:28 PM
I need to find a suitable slot to let this PC run for a few hours then. It's a tad difficult as it's in a bedroom so overnight is not an option.
Leave it with me
21-05-2013 9:36 AM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13691251636552.png"/>
I suspect you'd be seeing errors on the line in your graphs coinciding with those drops, if so we can definitely investigate that as a fault if you wish?
21-05-2013 1:05 PM
I'm probably up the wrong tree but I have a theory. During the week I don't use my PC at all = very little or no BB activity. Every morning I've been performing a Speedtest.net on my HTC Wildfire (wireless but within 1' of the router) at circa 05:00 and the results drop daily by a hundred or 2 Kb's. I take 3 readings and delete the slowest 2.
At the weekend I followed A1's advice and I downloaded and started Routerstat Lite. This was churning away in the background for most of the day presumably giving my connection a bit of a workout?
I had performed a PC speedtest via the utility here earlier in the day and I performed another speedtest using the checker here and my calculated speed had increased by 1.5mbps (ish) to a quite respectable 5.6Mbps from the just over 4Mbps earlier in the day.
So does DLM take usage/activity into account ?
This weekend I'm intending to fire up the PC and try to leave it running for the whole or as much of the 72 hours and see if I can get a Routerstat reading at a time when the connection has dropped for analysis.
Thanks for your time and leave it with me.
21-05-2013 3:12 PM
21-05-2013 4:03 PM
Funny my speeds should increase throughout Sunday with Routerstat 'giving it some' all day
24-05-2013 7:39 AM
Latest stats:
28/04/2013 5654
29/04/2013 4428
30/04/2013 4519
02/05/2013 4442
03/05/2013 4295
05/05/2013 4334
06/05/2013 5000 (Morning after PN reset)
07/05/2013 4097
08/05/2013 4242
09/05/2013 4819
10/05/2013 5130
12/05/2013 4732
13/05/2013 4673
14/05/2013 4632
15/05/2013 4493
16/05/2013 4481
17/05/2013 4457
18/05/2013 4396
19/05/2013 4369
20/05/2013 4585
21/05/2013 4687
22/05/2013 4404
23/05/2013 4469
24/05/2013 4395
Any chance of my latest dropout graphic as if I've had a continuous connection then probably not worth the exercise.
24-05-2013 8:27 AM
I assume from the way you have phrased your post, that the above are speed test results. It' might also be good if someone checks that your Current Line Speed matches the current BT IP Profile and bump it, if not.
Look forward to a few RSL graphs
24-05-2013 9:09 AM
Just looking for the same as Matt has posted above just to show me my latest history of disconnections. If I haven't had any since the last one shown above then no point in letting Routerstat do any monitoring.
= job done I'll go away
24-05-2013 9:16 AM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13693833501222.png"/>
I can also confirm your line profiles are matching, 4882 on BTs side and 4800 on ours.
24-05-2013 9:30 AM
24-05-2013 9:42 AM
Sunday 19th 08:00, 21:30
Tuesday 21st 18:00
That's starting to look stable now
Where are the router logs that show a longer history? The only one I've spotted only seems to have a short history mainly showing date and time updates.
thanks
24-05-2013 10:00 AM
The sort of entry you would see is -
Mar 21 12:16:56 xDSL linestate down
Mar 21 12:17:10 xDSL linestate up (ITU-T G.992.1; downstream: 7584 kbit/s, upstream: 832 kbit/s; output Power Down: 19.8 dBm, Up: 12.5 dBm; line Attenuation Down: 21.0 dB, Up: 14.0 dB; snr Margin Down: 6.1 dB, Up: 12.0 dB) (I pinched that from someone's post a while back).
Yours would have your own stats in of course.
24-05-2013 10:10 AM
On screen I can only see just over 24 hours worth of data which certainly wouldn't show my last disconnection on Tuesday as it will by now have dropped off the bottom. Is there a local logfile that shows a longer history?
24-05-2013 10:12 AM
