Speed
- Speed
Speed
03-09-2022 5:34 PM
What is it with plusnet internet not working well on Apple products. My iPhone never works well so I just never bother however just lately it’s not working well on my iPad. I can sit next to my husband whose devices work ok but mine don’t.
Message 1 of 2
(655 Views)
1 REPLY 1
Re: Speed
04-09-2022 11:37 AM
Hi, I've had similar things happen when I had multiple access points setup using the same SSID that were not aware of each other. You end up with contention between the WAPs and the device struggling for a connection.
The solution for me in the end was install a MESH wifi solution which solved the problem instantly.
Message 2 of 2
(604 Views)
