Speed through the floor.
- Speed through the floor.
Re: Speed through the floor.
10-11-2009 1:09 AM
10-11-2009 9:28 AM
BT filter. cordless phone.
System Up Time 19:48:05
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 56618 76393 0 148 1072 19:46:35
LAN 10M/100M 4039 0 0 6 0 19:48:01
WLAN 11M/54M/130M 172626 146848 0 1370 292 19:47:50
ADSL Link Downstream Upstream
Connection Speed 6368 kbps 448 kbps
Line Attenuation 31.0 db 31.5 db
Noise Margin 15.0 db 25.0 db
BT Filter Cordless phone. silent test running
System Up Time 19:51:13
WAN PPPoA 56618 76397 0 148 1069 19:49:43
LAN 10M/100M 4043 0 0 6 0 19:51:09
WLAN 11M/54M/130M 172783 146981 0 1367 292 19:50:58
Noise Margin 15.1 db 25.0 db
Corded phone BT filter silent test running
System Up Time 19:53:40
WAN PPPoA 56618 76397 0 148 1067 19:52:10
LAN 10M/100M 4061 0 0 6 0 19:53:36
WLAN 11M/54M/130M 172942 147117 0 1366 291 19:53:25
Netgear Filter Cordless phone
System Up Time 00:03:00
WAN PPPoA 25 8 0 12 5 00:01:25
LAN 10M/100M 68 0 0 44 0 00:02:56
WLAN 11M/54M/130M 279 234 0 718 158 00:02:45
Connection Speed 6336 kbps 448 kbps
Noise Margin 14.9 db 26.0 db
Netgear Filter Cordless phone silent test running - same as above
Netgear filter corded phone
System Up Time 00:07:50
WAN PPPoA 31 19 0 3 3 00:06:15
LAN 10M/100M 76 0 0 18 0 00:07:46
WLAN 11M/54M/130M 757 639 0 878 153 00:07:35
Netgear filter corded phone test running same as above.
With the Netgear filter and the router either unplugged or turned off, caller id works fine. Turn the router on and caller id doesn't work. With the BT filter caller id works in all situations.
It looks like my connection is pretty stable from tests run so far. I guess I could leave routerstats running overnight if you think that may be any use?
Guy.
Re:Speed through the floor.
10-11-2009 9:31 AM
10-11-2009 9:47 AM
If all is still OK tomorrow perhaps Matt can arrange the reduction in Target SNRM to 6dB?
Cheers for now.
10-11-2009 10:02 AM
10-11-2009 10:06 AM
11-11-2009 9:28 AM
System Up Time 19:40:39
WAN PPPoA 54088 72967 0 126 1043 19:39:43
LAN 10M/100M 2799 0 0 5 0 19:40:35
WLAN 11M/54M/130M 105731 82393 0 1309 175 19:40:24
Connection Speed 6272 kbps 448 kbps
Noise Margin 15.4 db 24.0 db
BT test
Download speedachieved during the test was - 207 Kbps
Additional Information:
Your DSL Connection Rate :6272 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5500 Kbps
WHOO HOO my IP profile has shot up. Now, how do I actually get some speed?
Cheers. Guy.
11-11-2009 9:43 AM
[me=jelv]pokes James[/me]
11-11-2009 9:48 AM
Guy - I've bumped your profile.
11-11-2009 9:59 AM
11-11-2009 10:37 AM
Guy.
11-11-2009 10:38 AM
11-11-2009 10:41 AM
11-11-2009 10:47 AM
11-11-2009 11:03 AM
Thanks to all who have chipped in along the way at this traumatic time :). Trouble is, now I know you're here I'll be pestering you for every iota of speed I can get.
Cheers, Guy.
ps - as an aside, I pointed the person (Riyaz) who replied to my original ticket raised last tuesday , in the direction of this thread, when I received a response on Sunday. I hope you have said you guys were dealing, and this is why I haven't heard anything on the ticket since? If so it may be an idea, for Riyaz to mention that in some way on the ticket, so it doesn't seem that c/s are providing a poor service and the only place you're going to get help in good time is on the forum!
