Speed through the floor.
- Speed through the floor.
Re: Speed through the floor.
07-11-2009 12:05 PM
07-11-2009 12:39 PM
07-11-2009 12:48 PM
07-11-2009 1:22 PM
07-11-2009 7:17 PM
ADSL Link Downstream Upstream
Connection Speed 6336 kbps 448 kbps
Line Attenuation 31.0 db 31.5 db
Noise Margin 15.1 db 26.0 db
which looks similar to the voyager. I guess I just have to sit back an wait for my profile to get better? Will keep updated. Ta.
07-11-2009 7:31 PM
07-11-2009 8:04 PM
07-11-2009 8:08 PM
07-11-2009 9:40 PM
07-11-2009 10:46 PM
09-11-2009 11:37 AM
Latest speedtest
Download speed achieved during the test was - 101 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :6720 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
Router stats.
System Up Time 23:51:08
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 162035 240644 0 456 2579 23:49:28
LAN 10M/100M 4534 0 0 6 0 23:51:04
WLAN 11M/54M/130M 249828 170416 0 2662 498 23:50:53
Connection Speed 6720 kbps 448 kbps
Noise Margin 13.8 db 25.0 db
At least someone from cs has replied to my ticket (5 1/2 days) so we'll see what they come up with! I'm at a loss. Guy.
09-11-2009 11:54 AM
09-11-2009 12:16 PM
Re:Speed through the floor.
09-11-2009 2:02 PM
Have you noticed any noise on the line at all? Your connection profile history looks quite random at the moment, and the fact that bits of your phoneline have stopped working is making me think there might be an issue there somewhere. If you dial 17070 from the handset, see if you can hear any crackles or noises or anything as that may well be the cause (if there are any you'll need to report them to your phone provider for fixing, don't mention the broadband if you do).
Hope that helps,
09-11-2009 2:57 PM
I've just run the silent test and sounded pretty quiet, no crackles and hums, I mean you can hear that you are electrically connected, but nothing more. There are some other interesting tests on the menu, anything worth trying? It seems that the loss of caller ID was down to the micro filter supplied with the Netgear router. I've replaced the bt one and ID is back. Odd eh?
Cheers, Guy
