Speed through the floor.
- Re: Speed through the floor.
- « Previous
- Next »
17-11-2009 3:16 PM
Hi killies,
One of our agents is talking to BT for you now to try and speed this through, I'll post back when there's more information. Should be in about half an hour, I'm hoping
Message 91 of 98
(593 Views)
17-11-2009 3:54 PM
Right - done. If it hasn't taken effect now it should do within the next half hour.
Message 92 of 98
(593 Views)
17-11-2009 5:53 PM
Sorry chaps, been out. Just checked and IP profile is up to 6500k - looking good. Looking at the stats, I'm guessing I'm getting close to my maximum? With the noise margin around 10dB am I right in thinking that a temporary increase in noise may cause instability if its pushed further and I'll be back to square 1? Ta, Guy.
Message 93 of 98
(593 Views)
17-11-2009 7:17 PM
A temporary increase in noise will only cause a problem if the noise margin approaches zero and the router reconnects at a slower speed to maintain a decent noise margin.
Message 94 of 98
(593 Views)
18-11-2009 6:41 PM
Hi Guy,
Can you post your latest ADSL stats, maybe a set this evening and a set in the morning. It sounds like your Target SNRM has been reset to 9dB. If your line remains stable, ie no connection drops, (no multiple reboots!), low error rate the DLM may drop it to 6dB in due course.
Message 95 of 98
(593 Views)
25-11-2009 12:27 PM
sheepish Total apologies Chris, didn't mean to blank you, didn't spot your last post. Have been sitting on things for a week to see how things panned out. Been stable as heck. Router stats from this morning
System Up Time 123:26:52
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 5700661 8111916 0 2264 9492 123:26:12
LAN 10M/100M 111549 0 0 68 0 123:26:48
WLAN 11M/54M/130M 8300898 5883695 0 379 2541 123:26:37
ADSL Link Downstream Upstream
Connection Speed 7616 kbps 448 kbps
Line Attenuation 32.0 db 31.5 db
Noise Margin 10.2 db 26.0 db
BT result
Download speedachieved during the test was - 3849 Kbps
Additional Information:
Your DSL Connection Rate :7616 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
BT generally reports slower than mybroadbandspeed, here's a snapshot
Date Download Speed Upload Speed
Today 12:17 5685 kbps (711kB/s) 3 81 kbps (47.6kB/s) Share
Friday 09:45 5514 kbps (689kB/s) 382 kbps (47.8kB/s) Share
Friday 00:38 3619 kbps (452kB/s) 380 kbps (47.5kB/s) Share
Nov 19, 20:09 4196 kbps (525kB/s) 379 kbps (47.4kB/s) Share
Nov 18, 00:28 4528 kbps (566kB/s) 371 kbps (46.4kB/s) Share
Nov 18, 00:25 4949 kbps (619kB/s) 343 kbps (42.9kB/s) Share
Nov 18, 00:23 3789 kbps (474kB/s) 371 kbps (46.4kB/s) Share
Nov 17, 19:05 4048 kbps (506kB/s) 379 kbps (47.4kB/s) Share
Nov 17, 18:44 4848 kbps (606kB/s) 380 kbps (47.5kB/s) Share
Nov 17, 18:25 4912 kbps (614kB/s) 376 kbps (47kB/s) Share
Nov 17, 18:19 5078 kbps (635kB/s) 381 kbps (47.6kB/s) Share
Nov 17, 17:45 5021 kbps (628kB/s) 382 kbps (47.8kB/s) Share
Nov 17, 08:35 5087 kbps (636kB/s) 381 kbps (47.6kB/s) Share
Nov 16, 15:15 5040 kbps (630kB/s) 381 kbps (47.6kB/s) Share
Nov 16, 13:38 5015 kbps (627kB/s) 381 kbps (47.6kB/s) Share
Nov 16, 12:08 3932 kbps (492kB/s) 381 kbps (47.6kB/s) Share
Nov 16, 09:50 4088 kbps (511kB/s) 380 kbps (47.5kB/s) Share
Nov 16, 09:47 3790 kbps (474kB/s) 380 kbps (47.5kB/s) Share
Nov 16, 09:45 3691 kbps (461kB/s) kbps (47.8kB/s) Share
Nov 14, 16:54 1045 kbps (131kB/s) 375 kbps (46.9kB/s) Share
Nov 14, 16:38 3544 kbps (443kB/s) 373 kbps (46.6kB/s) Share
Nov 14, 16:35 2603 kbps (325kB/s) 376 kbps (47kB/s) Share
Nov 14, 16:34 4368 kbps (546kB/s) 380 kbps (47.5kB/s) Share
Nov 14, 16:33 4780 kbps (598kB/s) 379 kbps (47.4kB/s) Share
Nov 14, 10:30 4499 kbps (562kB/s) 329 kbps (41.1kB/s) Share
Nov 13, 11:28 4575 kbps (572kB/s) 365 kbps (45.6kB/s) Share
All looks pretty good. Of course wouldn't turn up my nose at a bit more speed, but all in all infinitely better than it was. In fact much better than I ever had with my previous router.
Again, apologies for missing your post, cheers, Guy.
BT result
Message 96 of 98
(593 Views)
25-11-2009 12:51 PM
Hi Guy,
OK, no problem, it's looking v.good. With the ongoing network issues hopefully being resolved, you should see those speeds more often
Message 97 of 98
(593 Views)
25-11-2009 2:05 PM
Cool, seems like a few people have been having issues lately, ta.
Message 98 of 98
(593 Views)
- « Previous
- Next »
