Speed through the floor.
- Re: Speed through the floor.
09-11-2009 3:01 PM
09-11-2009 3:35 PM
09-11-2009 3:56 PM
You can do this test without disconnecting the broadband. I'd like to see a comparison of the stats when the wired phone is in use (e.g. listening to the quiet line test) and the cordless phone is in use. Yours wouldn't be the first to cause problems!
Is the base unit near the router (i.e. closer than 2 or three feet)?
09-11-2009 4:04 PM
09-11-2009 4:10 PM
09-11-2009 4:14 PM
09-11-2009 4:21 PM
Wired phone plugged in
System Up Time 02:54:59
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 5076 5615 0 156 327 02:53:29
LAN 10M/100M 424 0 0 5 0 02:54:55
WLAN 11M/54M/130M 6349 5638 0 353 171 02:54:44
ADSL Link Downstream Upstream
Connection Speed 6368 kbps 448 kbps
Line Attenuation 31.0 db 31.5 db
Noise Margin 15.4 db 25.0 db
Wired phone test running
System Up Time 02:56:55
WAN PPPoA 5078 5619 0 154 323 02:55:25
LAN 10M/100M 426 0 0 5 0 02:56:51
WLAN 11M/54M/130M 6435 5705 0 353 170 02:56:40
Cordless plugged in
System Up Time 02:58:42
WAN PPPoA 5078 5619 0 153 320 02:57:12
LAN 10M/100M 428 0 0 5 0 02:58:38
WLAN 11M/54M/130M 6464 5727 0 351 169 02:58:27
Noise Margin 15.3 db 25.0 db
Cordless plugged in test running
System Up Time 03:00:35
WAN PPPoA 5078 5619 0 151 316 02:59:05
LAN 10M/100M 439 0 0 5 0 03:00:31
WLAN 11M/54M/130M 6601 5827 0 355 168 03:00:20
Not much difference?
09-11-2009 5:19 PM
Keep an eye on those stats for the noise margin dropping.
Is that a Netgear router? If so you could run RouterStats which gives you a graph of your noise margin. http://www.vwlowen.co.uk/internet/files.htm#routerstats
Edit: Just back through your posts and seen it is a Netgear - thoroughly recommend router stats. You can set an alarm to sound if the noise margin drops below a level you can set
09-11-2009 5:35 PM
One thing I didn't suggest before is to watch the noise margin while the phone is ringing for an incoming call.
09-11-2009 5:54 PM
Edit: Forgot to say, it is known that some filters mess up the CLI signal for Caller Display, I'm surprised that the ones that have come with your new Netgear are that ****. Just for the record are there any identifying marks model version numbers on those filters?
09-11-2009 6:01 PM
09-11-2009 6:39 PM
Quote Just for the record are there any identifying marks model version numbers on those filters?
The only No. on the netgear filters is ACC-107-012 There is also the no. 31/09. I suppose there is a remote possibility the problem was sorted simply by the act of unplugging the filter and re-connecting. May check it out. There is a thread on the subject on the netgear forum tho.
09-11-2009 10:19 PM
System Up Time 09:01:30
WAN PPPoA 35406 47592 0 218 1444 09:00:00
LAN 10M/100M 2754 0 0 8 0 09:01:26
WLAN 11M/54M/130M 131250 115860 0 1870 491 09:01:15
Noise Margin 15.1 db 25.0 db
Have been monitoring routerstats - downstream noise margin between 15dB and 15.3dB consistently.
09-11-2009 10:35 PM
Stats look good, on course for a Target SNRM reduction, if you can post some from during the day say after 0830 but before 1530 that'd be good.
Did you try monitoring the Margin as there was an incoming call ringing on the line?
09-11-2009 11:53 PM
