Speed problems, down to 138kbps
- Speed problems, down to 138kbps
- « Previous
- 1
- 2
- Next »
Re: Speed problems, down to 138kbps
02-09-2010 8:07 AM
Am I right that the test should be done with a standard wired phone and not a DECT type?
Quote from: ReedRichards Any noise on the line? You can dial 17070 then option 2 for the BT quiet line test.
02-09-2010 8:27 AM
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
02-09-2010 8:58 AM
If there is noise then a check using a wired phone is needed to confirm it isn't the DECT phone causing it
02-09-2010 9:03 AM
With regard to your original question, the DLM registered a sync rate of 160k yesterday at about 16:16hrs when it lowered your profile to 135. So I'm not sure what the situation was with your connection at the time, but just after 10 o'clock last night it picked up again and went back to 2000, so you should notice a big difference today.
Jojo
02-09-2010 11:21 AM
02-09-2010 11:53 AM
I think it's the noise margin that's probably keeping you from getting a higher rate, so we could possibly perform a reset of that which could give you potentially another 1.5meg. However I can't guarantee that what caused the SNR to increase in the first place won't strike again and you would also have to go through the 10-day training period, but we can give it a try if you like?
Jojo
02-09-2010 12:15 PM
02-09-2010 4:10 PM
I've placed the order for the reset and it usually works in about half an hour but something doesn't seem to have worked yet. I'll try i again later and if no joy I'll have to wait until the morning.
Jojo
02-09-2010 10:46 PM
02-09-2010 10:52 PM
I've just done a line check and the noise margin now seems to be at 6 now but the sync hasn't increased, maybe a reboot will help. Are you connected to the master socket or on an extension?
Jojo
03-09-2010 4:57 PM
03-09-2010 5:10 PM
I can only imagine there must be some external noise for it to shoot up so rapidly. Don't forget the training period so stick with it. It's probably best not to over-analyse things too much at this stage (easier said than done, I know) but we'll monitor things and see how it settles down.
Jojo
03-09-2010 6:03 PM
- « Previous
- 1
- 2
- Next »
