Speed or lack there of... Again
- Re: Speed or lack there of... Again
21-05-2014 4:47 PM
Message 1 of 7
(1,170 Views)
6 REPLIES 6
21-05-2014 4:57 PM
Hi Mike,
I've just taken a look at your line and it's still running between the Cabinet and your Modem at the same rate as it was when our Faults Team last communicated out to you.
What speeds to you get connected directly to the Modem? Was the speed test you run completed by Ethernet?
Message 2 of 7
(587 Views)
22-05-2014 10:23 PM
Message 3 of 7
(587 Views)
23-05-2014 9:26 AM
Is there any difference when connected directly to the Openreach Modem via PPPoE connection?
http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
Message 4 of 7
(587 Views)
28-06-2014 1:56 PM
Sorry for the late reply. As a self employed person I've been so busy until now. I followed the instructions you gave me and connected directly to the modem, Once I remembered my pw
Here's the results of a speedtest PPPoE:
Still under the 13 - 14 Mbps I was getting since the last engineer visit. So I take it the reduced speed is not because of my hardware?
And a result using the router again:
Message 5 of 7
(587 Views)
30-06-2014 11:01 AM
Thanks for that.
Can you please visit http://faults.plus.net and raise a fault so that our Faults Team can investigate further?
Message 6 of 7
(587 Views)
01-07-2014 4:06 PM
Done that, Thanks.
Mike
Mike
Message 7 of 7
(587 Views)
