Speed keeps dropping
- Speed keeps dropping
- « Previous
- Next »
Re: Speed keeps dropping
06-08-2011 12:56 AM
Followed advice of Matt (thanks) and did speed test.
06-08-2011 12:59 AM
in which case, uncapping the US should not cause a problem (altho im suprised theres still a ~3 meg discrepency between throughput and profile...)
The increased US will reduce the chances of it being 100% saturated, and should improve performance - providing the line can remain stable
I'd give it a couple more days -- you might find tomorrow (later today?) that throughputs picked up even more and the lines settling
Regards
08-08-2011 10:20 AM
Are you running that speed test wired or wirelessly? Is there anyone else on the network or anything else running when you conducted it?
I've checked your Traffic management profile and everything is ok there.
Jojo
08-08-2011 2:39 PM
Will try later with uploading and xbox as I think it should have been uncapped today.
08-08-2011 2:44 PM
08-08-2011 4:09 PM
EDIT:
Just tried uploading and playing xbox and it was so badly lagging and kept coming up saying connection problem, the second I cancelled the upload xbox ran fine not a single lag was had.
Also had a random disconnection about 30 minutes ago, the internet light on our thomson router went red, but not showing up as a disconnection in the stats.
09-08-2011 11:55 PM
10-08-2011 10:08 AM
Let us know if you have any other problems.
15-08-2011 10:41 PM
Any ideas whats next to try?
15-08-2011 11:40 PM
if you mean it increases lag, when your uploading photos etc. to FB then it may be worth setting up QoS (Quality of service, basically your router gives priority to a device, or port, or protocol (like web browsing)without having a 585 to hand, i cant help with that though currently)... or simply limiting the upload speed of the transfer your doing (Which should stop it killing the xbox)
Regards
16-08-2011 2:18 PM
It is also slowing down general browsing as well.
Not sure how to limit the upload speed but would that really make a difference considering it caused problems before it was uncapped?
16-08-2011 5:32 PM
You can set limits on individual programs (e.g. IE, set to 20KB/s upload) would only allow IE to upload at that speed.
If the reason your dropping out is because the comp is 'saturating' the bandwidth (e.g. theres an increased latency, or you cant do as much - because obviously your sharing the available bandwidth)
so it might make a difference, e.g. you can upload at 30KB/s, xbox is using 20KB/s and you start to upload a photo, this goes straight to 30KB/s and starts to slow (whilst this is happening, the XBOX has less/insufficient bandwidth) and would cause drop outs / poor ping etc.
Thats the first way, another way is swapping out the router (ive only seen D-Links to QoS *simply* and they do it well) -- however their customer service is an abomination - and you have to use IE6 to use their support wizard if you have a problem.
Regards
16-08-2011 5:39 PM
Quote Smooth, Responsive Net Connection
Quality of Service (QoS) gives users full control over outgoing data traffic. Priority can be assigned by the router to ensure that important transmissions like gaming packets, VoIP calls or IPTV/streaming content passes through the router at lightning speed, even when there is heavy Internet traffic. The speed of different types of outgoing data passing through the router is also controlled to ensure that users do not saturate bandwidth with their browsing activities.
16-08-2011 6:33 PM
I know I have asked this before but it seems like the prioritising thing I should have on my package isnt working as I was told that gaming should always be prioritised but doesnt seem to be?
16-08-2011 7:07 PM
But so is web, so on YOUR network it wont make much difference to you (gaming isnt 'over' web for example, until it gets to plusnet for them to sort out )
I'll see if i can find a *working* router in my stash of spares (which i no longer need) you can borrow to test see if it makes a difference... I'll let you know if I find it
Regards
- « Previous
- Next »
