Speed has crashed
David_W
Speed has crashed
For some reason my speed seems to have dropped off signifigantly.  I was trying to watch programmes on Crunchyroll in HD which my connection can handle with ease but it got juddery, that was yesterday so tried again today at 480p and again with the judder.  I ran a test on mybroadbandspeed which was hovering around 300k before jumping to 900 (I think it's Kaspersky that breaks that) so ran a BT speedtest:
Download speedachieved during the test was - 1270 Kbps
Additional Information:
Your DSL Connection Rate :8096 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7000 Kbps
So my profile is fine, 7000 but my speed is well down on what it should be.  I'm not on managment, and even if I were it's off peak.
Router stats are:
DSL Status: Up
DSL Modulation Mode: GDMT
DSL Path Mode: INTERLEAVED
Downstream Rate: 8096 Kbps
Upstream Rate: 448 Kbps
Downstream Margin: 9db
Upstream Margin: 22db
Downstream Line Attenuation: 30
Upstream Line Attenuation: 15
Downstream Transmit Power: 19
Upstream Transmit Power: 12
Which is how it's been since I moved, although Margin is up from 8 to 9.  I can't think of any reason why my speed would fall over.  Any suggestions or should I just open a ticket?
9 REPLIES 9
jelv
Fixes: 10
Re: Speed has crashed
What does https://portal.plus.net/my.html?action=stable_rate say for your current line speed?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jojopillo
HI David W,
I've had a look from our end and can't see any obvious reasons. I'd firstly go through the troubleshooter: http://www.plus.net/support/broadband/bbfaults/slowspeed.shtml ; follow that though and if no better then definitely raise a ticket.
Jojo Smiley
David_W
I've ran through, my exchange is green, PC is clean so I'll try a different router during half time and see if that works, if it doesn't then I'll open a fault Smiley
7000 btw Jelv.
Fixes: 399
wired or wireless connection to the pc ?
David_W
Wired, switched router from my Buffalo to my Netgear, the connection speed changed:
ADSL Link Downstream Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 31 db 8 db
Noise Margin 6 db 26 db
Attenuation went up to 31 but Noise down to 6 so speed capped at 8128, which is nice, speed though:
Download speedachieved during the test was - 616 Kbps
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Went down, so time to open a ticket.  Good footie match!
David_W
Any chance ticket 33865370 could get a look at?  It hasn't been touched since Friday and my speed is still terrible.
jojopillo
HI David W, just spoke to someone in faults and got them to check it. They said they will update the ticket shortly.
Jojo Smiley
David_W
Cheers Joanne, the ticket got a kick up the backside and is moving forward really fast, had a nice chap from PN phone me up to let me know what was happening (problem with virtual path or something) so now it's twiddle thumbs time whilst waiting for BT to get their groove on.  Very impressive from PlusNet though (as always really).
jojopillo
Aw, glad we could help Smiley
