Speed dropping big time.
- Re: Speed dropping big time.
14-09-2013 7:15 PM
Download speedachieved during the test was - 51.28 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
14-09-2013 7:46 PM
15-09-2013 5:50 PM
FRASERBURGH
Estimated line speed:
76Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-07-18 16:08:33
Current line speed:
77.4 Mb
15-09-2013 6:02 PM
Download speed achieved during the test was - 47.06 Mbps
For your connection, the acceptable range of speeds is 16 Mbps-77.44 Mbps .
16-09-2013 2:15 PM
16-09-2013 2:30 PM
I'm sure they'll get to you soon.
16-09-2013 2:33 PM
I logged onto the router and did a disconnect then powered down the BT Modem for a few minutes, then I powered it back up, waited 5 minutes then powered the router back up.
I had to do this a few times in the first few months but mine seems pretty stable now.
16-09-2013 9:08 PM
I really wish I had gone with sky now.
17-09-2013 8:24 AM
nothing much can be done about that mind you unless BT provide more hardware to cope with all the fibre product there selling, also its not the speed that's dropping its the bandwidth, if the speed was changing your sync speed would be lower ....
17-09-2013 11:28 AM
17-09-2013 11:51 AM
17-09-2013 12:07 PM
17-09-2013 12:13 PM
Quote from: furrymunkey I have responded to the ticket 3 times and yet to hear a reply for support. ?
Every time you "bump" a ticket, it goes to the back of the queue - this could explain why you haven't had a reply.
17-09-2013 3:14 PM
