Speed dropped off
- Re: Speed dropped off
Speed dropped off
30-06-2008 6:02 PM
I'm running a D-link DKT-710, plugged into the master socket, I've disconnected all the extension lines.
Router stats are:
Downstream
Rate (Kbps): 1632
SNR Margin (dB): 12.4
Attenuation (dB): 63.5
Output Power (dBm): 12.3
I'm 2.92 km (direct) and 3.7 km (road) from the exchange, anyone else think this speed is crap?
30-06-2008 6:11 PM
Have you had any particular interference or wiring problems to push SNRM up from the normal 6dB or has it always been that (longer lines can be more prone to interference)?
30-06-2008 6:30 PM
Quote from: HPsauce It looks pretty good considering the attenuation (*line length) and Noise Margin (SNRM).
Na, the only thing I've done is replace a aging 5 year old netgear modem with the d-link. The master socket is right beside the electricty meter, dunno if that would cause interference as the electricy cable should be sheilded.
30-06-2008 6:47 PM
Quote from: thePhoolish as the electricy cable should be sheilded.
You cannot be serious!
It wouldn't really be the mains supply as such that causes interference but powered devices which can then broadcast interference back through the mains wiring as an aerial. Unless it's in an armoured conduit for a specific reason domestic mains wiring is definitely NOT shielded.
30-06-2008 7:08 PM
Quote from: HPsauce
Hmm, I'd have thought the mains supply would have been armoured to prevent accidental cuts.
I moved the router away from the meter box and the SNR rate dropped from 12.8 to 11.8, I thought a higher SNR was better?
Anything I can do to shield the router/adsl?
30-06-2008 7:22 PM
SNRM is a response to noise, it's set automatically at a level that gets the signal through effectively. For any given line a higher SNRM means slower data speeds so some people tend to "push" it to a lower figure (risking errors) to get higher speeds. 6dB is "normal" so yours is very high for some reason, which may be historical (the level can get "stuck" with BT's kit not readjusting).
Depending on your router you can adjust SNRM yourself to some extent; DMT tool is commonly used.
(FYI my line is currently at 3.1dB set with DMT and has had no significant errors in the last 24 hours)
30-06-2008 7:42 PM
30-06-2008 7:53 PM
30-06-2008 8:19 PM
30-06-2008 8:45 PM
a lowercase k denotes the prefix "kilo" as in kilogramme (kg)
m = "milli" as in millimetre (mm)
M= mega as in megawatt (MW) - watts are denoted by a capital W because they are use a surname. The same rule applies to joules and newtons.
As I understand it, bits are represented by a lowercase b and bytes by an uppercase B.
kb = kilobit
kB = kilobyte
Mb= megabit
MB = megabyte
Gb = gigabit
GB = gigabyte
[edit : these units are quantities of data. A speed is denoted by the quantity over time; i.e. kbps (kilobits per second) or MBps (megabytes per second).]
Unfortunately it doesn't seem to be common practice to stick to any single rule. It would really help to clear up ambiguities if everyone stuck to the same standards of notation.
Additionaly, a capital M on its own denotes a bolt size. "8M" is not a speed, it's a handy size of bolt for securing a wooden post to a concrete plinth.
30-06-2008 8:54 PM
Quote Unfortunately it doesn't seem to be common practice to stick to any single rule. It would really help to clear up ambiguities if everyone stuck to the same standards of notation.
30-06-2008 9:21 PM
Quote from: pierre_pierre go on HP now tell him your speeds
Lemmy guess.. 8Mb?
BT speed tester reports downrate at 1762 but actual speed was 740!!!
30-06-2008 9:34 PM
(20649kbps down and 1300kbps up at present if you really must know - a taste of things to come with ADSL2+, but not for you I'm afraid)
30-06-2008 9:53 PM
Quote from: HPsauce That means your profile is moving, which is good. Run the BT Speed Test to verify it.
20 times my rate.. any chance of a microwave linkup?
30-06-2008 10:03 PM
With your line length the "estimated" reasonable speed with ADSL Max is 1856kbps, which you're quite close to.
With ADSL2+ which BT are starting to roll out and PN will presumably make available in due course it's a massive increase for you to (wait for it) 1952kbps!
The only real gain is likely to be on upload speeds (sending emails); I'm not sure what BT are planning to do about those, but your 448kbps on ADSL Max could go to almost 1300kbps.
