Speed consistently at 1.5 Mbps for the last few days
jonne80
I been only getting around 1.5-1.6 Mbps for the last few days. When I started this contract I use to get around 2.5 Mbps, but the speeds been dropping and has come down to this.
http://www.speedtest.net/my-result/5308560151
Last time I had issues with speed, you guys had fixed my speed to around 2.2 Mbps (https://portal.plus.net/wizard/?p=view_question&id=120056604), but it has dropped and https://portal.plus.net/my.html?action=stable_rate also says 1.7, but its less than that.
And I cant see a way of creating a new ticket on your system anymore, hence I am posting here.
I hope you guys will be able to get it back to to 2.2 at least like you fixed it last time, 1.5 is too less a speed for London area, I feel as if I am in some rural area of UK.
Thank you.
5 REPLIES 5
SpendLessTime
Fixes: 86
Re: Speed consistently at 1.5 Mbps for the last few days
The Plusnet Broadband troubleshooter is here
Gel
Aspiring Champion
Fixes: 29
assume you've done the obvious of rebooted router to try & connect to a faster gateway?
Do this at off peak times.
Check your current gateway here:
http://usertools.plus.net/@gateway/
When you reconnect, keep checking your gateway, until you're on new one, then use the OPENREACH speed tester:
http://speedtest.btwholesale.com/
Chris
Legend
Fixes: 169
Best thing is to check the troubleshooting guides: http://www.plus.net/support/broadband/bbfaults/
If they don't help, report a fault: https://faults.plus.net
jonne80
Thanks all, I will go through the fault checker over the weekend.
Minivanman
Legend
Hope you get it sorted out, but I have had the same issue for nearly three months, and six engineer visits so far all of who seem at a total loss as to how to fix the problem. Engineer number seven to call Monday.
On the bright side and given you are not getting the service I would suggest you ask plusnet for a full refund as to date they have without hassle refunded me in full for both March and April although to be honest, I'd rather be able to watch videos on line and make phone calls without crackles in my ear.
Good luck, you might need it.
Truth is like a threshing machine; tender sensibilities must keep out of the way.
Herman Melville
