Speed Problems
- Speed Problems
Re: iplate
16-12-2008 5:17 PM
the OP's edit didnt make mine reply look correct, he said he had no reply
Re: iplate
16-12-2008 5:34 PM
Distance:- Direct: 1.55 km
(appx)* By Road: 2.41 km
DSL Max : 3500 kbps (3.5 Mb) BT Line Speed Estimation
Re: iplate
16-12-2008 5:38 PM
Quote from: okmbok [I get very very low background hum. No crackling
Hmm...
It should be totally quiet. What type of phone are you using - is it a cordless?
Any chance of you trying a different wired handset (if you could quiet line test your phone on someone else's line that would be great).
Re: iplate
16-12-2008 5:41 PM
Quote from: jelv
Hmm...
Yeah its a dect phone...I cant find my old corded phone atm
Re: iplate
16-12-2008 5:47 PM
Re: iplate
16-12-2008 5:53 PM
Quote from: jelv I've seen posts suggesting that Dect phones should be double filtered. Also when you did the test socket test, was the phone still plugged in to the filter? If so try again without the phone plugged in to see if you get a better sync and also make sure the DECT phone is totally turned off or moved well away from the phone socket and router.
Dect Phone was unplugged
Re: iplate
16-12-2008 6:00 PM
BTW - is there any electrical equipment near the phone line in or the router? (E.g. your router isn't sat on top of your PC - power supplies can generate a lot of electrical noise)
Re: iplate
16-12-2008 6:08 PM
Quote from: jelv Right - for a next step I'd recommend trying the quiet line test on a friends phone to see what it should be like and then borrowing their handset for 10 minutes to compare on your line.
Master socket is 20cm from Mains Wall Socket
Re: iplate
16-12-2008 6:24 PM
Quote from: okmbok
low background hum.
like mains hum at 50 Hz ?
What can I do to get back to 3.5mbps???
16-12-2008 6:28 PM
Router connected to Master socket. No extensions. Queit line test ok.
Router Stats:
ADSL Link Downstream Upstream
Connection Speed 2272 kbps 448 kbps
Line Attenuation 52 db 14 db
Noise Margin 12 db 20 db
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 2016 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 2000 kbps
Actual IP throughput achieved during the test was - 873 kbps
If you wish to discuss these results please contact your ISP.
[Moderator's note by Jim (Oldjim) Topics merged - please don't start a new thread on the same subject ]
Re: iplate
16-12-2008 6:47 PM
Connection Speed 1856 kbps 448 kbps
Line Attenuation 47 db 14 db
Noise Margin 14 db 20 db
Re: iplate
16-12-2008 6:47 PM
Routerstats is good for that and can give you good indications of when things go wrong.
Re: iplate
16-12-2008 6:51 PM
Re: iplate
16-12-2008 6:52 PM
Also with a noise margin of 14dB and 47dB attenuation you should be getting much faster speeds than 1856kbps
I may have missed it - but which router are you using
Re: iplate
16-12-2008 6:54 PM
