Speed Problem. Capped speed???
- Re: Speed Problem. Capped speed???
23-11-2010 8:16 PM
Was downloading around 5 o'clock speeds were 350kbps ish
Now it cant get past 30 -35 kbps ,have i been capped?
I cant understand whats going on i cant it being on my side as it fine a cuople of hours ago then bang down to snail speed.
Much appriciated
Lee
23-11-2010 8:18 PM
B.
23-11-2010 8:22 PM
Megavideo , rapid share files.
23-11-2010 8:26 PM
ADSL2+ Line State Show Time
Line Power State L0 Line Up Time 00:00:35:21
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 5152 Kbps 873 Kbps
Noise Margin 6.1 dB 5.7 dB
Line Attenuation 52.0 dB 28.5 dB
Output Power 0.0 dBm 13.0 dBm
23-11-2010 8:32 PM
Quote Megavideo , rapid share files.
Those are download servers (IIRC) which means from 6pm-10pm they are restricted to 256kbps on Extra (note the small b).
Take a look at the table here for the details: https://www.plus.net/support/broadband/speed_guide/download_speeds.shtml#extraSpeeds
23-11-2010 8:34 PM
23-11-2010 8:40 PM
Quote from: Chris
Does my router stats look ok, like avrage or poor?
Strange this has never happend before today.
Id br happy with 256kbps but 30?
Not happeh
23-11-2010 9:04 PM
23-11-2010 9:16 PM
Anyone know any onther companies that dont do this as aggresively?
if so pm their number cheers.
23-11-2010 9:20 PM
My speed has gone to 140k ish now
very strange.
