Speed Issue again - ticket needs answering
- Re: Speed Issue again - ticket needs answering
24-09-2010 9:15 AM
Reporting on behalf of a friend - account gnomehouse
Seems performance has dropped on his line again - can someone have a look at ticket 35364966.
Things had been stable at 6500 but now it's 130 for download. Looking at his connection speed on the port it seems this has now dropped to 250.
He's tried the master socket and it makes no difference. He has ran the fault checker and is awaiting a response from PN as to the next steps.
Regards,
24-09-2010 9:44 AM
a few things;
these connections over the last week won't have helped
They need to make sure they stay in the test socket while the checks are taking place
The fault was raised at 10 o'clock last night and updates can take up to 72 hours.
I have just ran a line test and they have a good sync rate with a profile of 1500 I have matched our profile to this so they should see an improvement now. This should lift even further should there be no more drops.
Jojo
24-09-2010 9:50 AM
Thanks for the response and information. I'll take a look at his router over the weekend and make sure it's setup correctly.
Hopefully we can get to the bottom of the matter.
Cheers,
24-09-2010 10:21 AM
24-09-2010 10:29 AM
24-09-2010 10:32 AM
24-09-2010 11:12 AM
I'll raise that with him when I speak to him.
24-09-2010 11:53 AM
24-09-2010 12:06 PM
24-09-2010 12:39 PM
It could be many things. If he rules out everything from his side then we will have to see what the faults team make of it.
Jojo
24-09-2010 1:44 PM
24-09-2010 1:49 PM
make sure he has definitely performed all the tests required in the faults ticket and maybe look here too.
Jojo
01-10-2010 8:12 AM
Seems internal wiring is the main culprit and tests have proved that. Current temporary setup has produced :-
1. sync of 7616
2. downstream attenuation ot 19 and Noise Margin of 15
3. Upstream attenuation of 5.5 and Noise Margin of 24
4. PN Profile of 6500
5. less crackle when using the phone handset.
The noise margin of 15 flips between 15 and 14 every few minutes on a Routerstats graph (can't post them due to PC access). What further steps can be taken to reduce the NM or make it more steady ?
01-10-2010 8:34 AM
Because of the problems BT have raised the target noise margin to try to stabilise the line. If it remains synced with no problems BT will gradually reduce the target - this may take some weeks.
Alternatively, if it has remained stable for a number of days you could ask PN to retrain the line.
01-10-2010 8:56 AM
I think my friend is going to sort out the wiring on a permanent basis first. Once that is complete I'll suggest he monitors for a few weeks and if no joy, then request a retrain. His exchange is due 21CN next March and I've suggested he gets things stable before moving to that.
