Speed Help!
- Speed Help!
- « Previous
- 1
- 2
- Next »
Re: Speed Help!
10-03-2009 11:27 PM
PM sent Oldjim,
For anyone else:
For anyone else:
Message 16 of 20
(213 Views)
Re: Speed Help!
11-03-2009 10:02 AM
It's not a fixed line Adie. You can tell because there is an IP Profile being applied on the BT Speedtester.
It's possible that the line is being capped due to instability - but there is clearly something wrong.
Please do raise a fault @ http://faults.plus.net and we'll look into it for you.
Message 17 of 20
(213 Views)
Re: Speed Help!
11-03-2009 10:04 PM
Have you tried another Filter yet? If no change you need to borrow/try another router. I know this was suggested earlier but I haven't seen a response on that.
Message 18 of 20
(213 Views)
Re: Speed Help!
12-03-2009 8:36 PM
Guys,
Having read a few opinions about Plusnet Customer Service standards in the past, id just like to say that i have had nothing but top information and advice with this issue so far.
Bravo Plusnet!
Alas i only wish BT were as efficient. Each time i ring, i get treated like its the first time i have rang. I understand i will speak to a different operator each time, i expect it. But to have to confirm the same tests only to be told that my line is testing fine and told to contact Plusnet again is a tad depressing.
What can i do?
Ive tried 3 filters mate all with the same result
Bravo Plusnet!
What can i do?
Message 19 of 20
(213 Views)
Re: Speed Help!
12-03-2009 8:44 PM
Unless you have a phone somewhere which you can try there is no point in calling BT as they will only accept voice line faults.
Now if you can get/beg/borrow a corded phone and try the quiet line test, without your router connected, dial 17070 option 2. If you can hear crackles/noise etc. then call BT and report a voice fault - don't mention broadband.
If there isn't any noise or you can't get a phone report a broadband fault to Plusnet by starting the fault report http://faults.plus.net/ and they will then pick it up.
BT Retail who supply your voice line won't and can't help with a broadband fault
Message 20 of 20
(213 Views)
- « Previous
- 1
- 2
- Next »
