Spam Filters
- Re: Spam Filters
Spam Filters
19-03-2008 11:17 PM
Hi all,
I use Microsoft outlook as my mail client, I download mail from the squirrel mail folders yet quite a lot of it recently has been marked as spam by squirrel and not downloaded. This means every couple of days I have to check squirrel and mark it as not spam and then manually forward it to my inbox. This is becoming a pain is there anyway than I can set-up in squirrel a list of certain email domains that are not spam. eg. *@boots.com or *@marksandspencer.com
Or can anyone suggest a work around?
Richard
Richard
Message 1 of 5
(1,067 Views)
4 REPLIES 4
Re: Spam Filters
19-03-2008 11:30 PM
Whitelisting is something Plusnet is working on at the moment, and should be with us v.soon.
What I do (using Outlook Express, but I'm sure Outlook works much the same) is have my tagged spam downloaded and moved to my Delete folder using a Message Rule. I can then check it for false positives before easily ditching it. If you have a lot of spam this would use up bandwidth and be a bit anti-social....
To stop spam being put in your webmail spam folder, go to Manage My Mail from the Members Centre, click on the Spam tab, and find the option to have the spam filter on and delivering spam to your email client.
Message 2 of 5
(389 Views)
Re: Spam Filters
19-03-2008 11:34 PM
What version of Outlook do you use?
I've got 2003, which (along with 2007) has a pretty good spam filter of its own.
As a result I've turned off all spam filtering at my email hosting services; saves quite a bit of messing about.
Message 3 of 5
(389 Views)
Re: Spam Filters
20-03-2008 1:31 AM
Can't wait for the whitelist to arrive - then maybe I can get my Facebook e-mails without having to read all the obscene subject lines on my Spam.
When will the Spam filter learn that Facebook does not send Spam? I keep forwarding them to Not Spam
I'm getting about 60 Spam a day at the moment - more than I was getting at Xmas. It's increasing all the time, three weeks ago I was getting about 15 day - anyone got any idea why its gone up so much?
Message 4 of 5
(389 Views)
Re: Spam Filters
20-03-2008 11:24 PM
Quote from: HPsauce What version of Outlook do you use?
Cheers I will have ago at this I have 2003 and plan to buy 2007 soon.
Message 5 of 5
(389 Views)
