Sorry.....But I am sick to death with the problems on my line.
- Re: Sorry.....But I am sick to death with the prob...
Re: Sorry.....But I am sick to death with the problems on my line.
29-10-2012 3:58 PM
Alex
29-10-2012 4:21 PM
I don't know how well you get on with your neighbour on the Village Network, but if you can see if he was doing anything with his connection at ~1140-1145, just a discreet enquiry, nothing suggestive of blaming him or it being his fault (even if it turned out to be that network) - it's a case of trying to eliminate any obvious possibilities, as you may recall we've talked about before.
Should it ever turn out to be that, then we'd have to consider what methods would be best to minimise or eliminate such interference.
29-10-2012 5:13 PM
29-10-2012 5:21 PM
Alex
29-10-2012 5:31 PM
Any one else near you with Village Network? Have a gander in particular if any of the antenna point over you (obviously will depend on neighbour location and location of mast supplying feed).
30-10-2012 8:39 AM
In my close there are at least 4 users of Village Networks....yes some of their antenna dish things do point over my house to the supplying mast. Overall on this estate there are many 10's of households on the Village Networks. If it were to be any one of these households that was my potential problem.....I really do not knoe how I / anyone would/could find out. Although I do not like doing this....if VN was the cause then I think I would have to treat the symptoms.
Have held this sync for nearly 21 hours now SNRM trundling along 8.5db area, dropping to 7.5db for a few hours during yesterday evening.
Alex
30-10-2012 8:59 AM
Let's hope the sync continues to hold.
30-10-2012 2:42 PM
Alex
30-10-2012 3:37 PM
30-10-2012 4:55 PM
But a TPM hasn't been done which is one option that ought to be tried just in case, if the problems continue to affect performance.
(I say problems because there could be two separate things going on here).
31-10-2012 3:31 PM
I was around when the resync happened....so I got the Router DSL stats....within abount 13 minutes. Whatya think?
01-11-2012 2:55 AM
Whatever the cause, there's a lot of FEC & CRC errors in that short uptime, suggesting the presence of noise/line disturbance somewhere, also reflected in the RSL plot.
IIRC on the 582n, a resync causes the FEC & CRC error count to be reset (but not the HEC error count).
Thankfully the sync speed didn't drop much. What's your Current Line speed (Login required) ?
Edit: see Reply #57, new information.
01-11-2012 12:14 PM
Alex
01-11-2012 1:25 PM
01-11-2012 1:40 PM
