Something wrong
- Re: Something wrong
Re: Something wrong
02-08-2015 4:50 PM
I suggest you go about diagnosing you noise issue making sure you gracefully disconnect before poking around. I also suggest that at any time you goto switch on your modem/router and connect, that you check the line is free of noise beforehand which will at least hopefully give you a reasonable connection speed until it drops.
Re: Something wrong
02-08-2015 5:22 PM
So you didn't see my post #46? Or your own reply #47?
<i>Those remarks and your total lack of response to some of my posts shows that you do not understand the complexities that can be involved.</i>
There, there! Don't you worry your pretty little head about that.
<i>Your most recent problems appear to have got worse around the same time you bought a new TV, so there has to be a suspicion that there maybe an issue with it causing interference.</i>
WHAT?!!!
Baby, I've had enough. I just want out of this [Censored]. [You do the math. ]
What happened? Plusnet used to have a good reputation. Now its "Lets's insult the customers - that'll work well!"
I'll just sort something out myself in my own time and migrate when I can.
FINIS.
Re: Something wrong
02-08-2015 5:37 PM
Quote from: pvmb What happened? Plusnet used to have a good reputation. Now its "Lets's insult the customers - that'll work well!"
You do realise that Anotherone is just a customer like you and me?
However unlike you and me he is a customer who knows a great deal and can actually help you here.
Even me, who knows only a fraction of what Anotherone does, can see from your responses that you don't quite have a handle on the intricacies of ADSL BB problems and have a number of wrong ideas.
Quote I'll just sort something out myself in my own time and migrate when I can.
FINIS.
Ok as long as you're happy that the problems will probably still be there with another provider.
Re: Something wrong
02-08-2015 6:48 PM
I was starting to clutch at straws in reply #47 because you hadn't posted what was asked, then or previously as already mentioned.
Quote from: pvmb <i>Your most recent problems appear to have got worse around the same time you bought a new TV, so there has to be a suspicion that there maybe an issue with it causing interference.</i>
WHAT?!!!
It seems, in my confusion because of the following -
Quote from: cedlor Not really if there is external line noise from a skybox/TV/ railway /electric fence/ intruder alarm/ street lights
(list is endless) it will be picked up whether the router is switched on or not.
Quote from: pvmb Really? You mean like my TV receives BBC programmes when it is switched off? Also - if it makes "no diference" then switching it off doesn't actually matter, does it?
I've got you mixed up with someone else that bought a new TV and their problems started around that time. This wasn't helped by my recollection of your comment about high ES errors in the middle of the day - potentially indicative of some source of interference.
So for that confusion,. I apologise
However, the rest still stands as
Quote from: pvmb <i>Those remarks and your total lack of response to some of my posts shows that you do not understand the complexities that can be involved.</i>
Comments like that totally justify my opinion. I've given you good advice and where to find it, and as jem16 has remarked, if your line problems remain, they won't magically disappear if you go somewhere else.
Re: Something wrong
02-08-2015 7:33 PM
If as you say, you have an intermittent line / noise problem that should be sorted first. Line issues are generally sensitive to the weather, when it is wet (especially very wet) they come; when it dries up they go away.
An inbound phone call can 'fix' a marginal line fault for days - the higher power of the ring signal can 'clean up' iffy joints.. AO has given good advice and sought answers to specific questions to help profile the problem. If you really want help, then please answer those reasonable questions.
Re: Something wrong
02-08-2015 7:33 PM
Quote I've got you mixed up with someone else that bought a new TV and their problems started around that time. This wasn't helped by my recollection of your comment about high ES errors in the middle of the day - potentially indicative of some source of interference.
Well thank you for that. Apology accepted.
However..
Quote Those remarks and your total lack of response to some of my posts shows that you do not understand the complexities that can be involved.
Quote There, there! Don't you worry your pretty little head about that.
The existing problem I had on my line with TalkTalk did when I left TalkTalk for Plusnet.
And hopefully they may be more sympathetically and constructively dealt with elsewhere.
P.S.
The link is disappearing again during this reply. (On a WIRED computer. On a different computer.)
"The following error or errors occurred while posting this message:
Your session timed out while posting. Please try to re-submit your message.
No subject was filled in.
The message body was left empty."
Re: Something wrong
02-08-2015 7:37 PM
As for the previous problem disappearing when you left Talktalk and came over to PlusNET, well that depends on what the problem was. Talktalk and PlusNET use different equipment in the exchange. This looks most certainly like a line or in home line problem and will remain no matter which ISP you use.
Re: Something wrong
02-08-2015 7:43 PM
Quote from: pvmb The existing problem I had on my line with TalkTalk did when I left TalkTalk for Plusnet.
I thought you had decided your problems were intermittent?
However apart from that TalkTalk use LLU equipment, PlusNet does not. So perhaps whatever was wrong with your TalkTalk equipment was down to its own LLU equipment as opposed to the actual line supplied to all ADSL suppliers by Openreach. As there seems to be a noisy line involved that will affect all suppliers apart from Virgin Cable.
Quote And hopefully they may be more sympathetically and constructively dealt with elsewhere.
If it's back to TalkTalk there's no chance of that given their dire reputation for Customer Service.
Still the choice is yours.
Re: Something wrong
02-08-2015 8:07 PM
Quote The existing problem I had on my line with TalkTalk did when I left TalkTalk for Plusnet.
The problem I had when I was with TalkTalk was the problem I had when I was with TalkTalk. The problem I have NOW is the problem I have NOW, when I am with Plusnet. They are entirely different problems. The one thing they are proving to have in common is that they are intractable. I solved the TalkTalk problem by leaving TalkTalk for Plusnet. Perhaps there is a hint there of how I can solve the problem I have now I am with Plusnet?
Quote However apart from that TalkTalk use LLU equipment, PlusNet does not.
Unbelievably - I know this.
Quote So perhaps whatever was wrong with your TalkTalk equipment was down to its own LLU equipment as opposed to the actual line supplied to all ADSL suppliers by Openreach.
It was. IMHO.
Quote As there seems to be a noisy line involved that will affect all suppliers apart from Virgin Cable.
Depends where the noise is originating.
I get the impression Plusnet is working hard to close that gap.
Quote Still the choice is yours.
Indeed.
Red light on modem again.
Re: Something wrong
02-08-2015 8:10 PM
If there is noise please raise a phone line fault report using the link below.
Re: Something wrong
02-08-2015 8:37 PM
Re: Something wrong
02-08-2015 8:38 PM
Quote from: pvmb Excuse my bluntness (born of frustration) but everyone on here seems to have a truly amazing capacity to miss the point:
Excuse my bluntness but that does seem to refer to you.
Narrowing down the problem requires your co-operation in supplying the information asked for, not just for fun, but because it's necessary.
Quote Perhaps there is a hint there of how I can solve the problem I have now I am with Plusnet?
Not unless you're in the habit of putting 2 and 2 together to make 5.
Quote Depends where the noise is originating.
Of course it does but you seem to have eliminated BT Openreach's equipment without knowing if it is or isn't that.
Quote I get the impression Plusnet is working hard to close that gap.
Probably would agree with you there with recent developments regarding telephone support and tickets.
However the people trying to help you here, notably Anotherone, are not PlusNet staff.
Re: Something wrong
02-08-2015 11:32 PM
How you can POSSIBLY draw that conclusion is entirely beyond my comprehension.
Anyway, I have decided to try and investigate this problem for now, as far as I can, using my own devices. So don't worry about it.
Re: Something wrong
02-08-2015 11:54 PM
Second, assuming it is a DECT phone, when disconnecting it do you just remove its phone cable from the phone socket, or do you also remove its power plug from the mains socket? (Or switch the mains socket off if it has a switch).
Re: Something wrong
03-08-2015 10:34 AM
Quote from: pvmb How you can POSSIBLY draw that conclusion is entirely beyond my comprehension.
Probably just the fact that you feel moving away from PlusNet will solve your problem.
Quote Anyway, I have decided to try and investigate this problem for now, as far as I can, using my own devices.
A little less bluff and bluster might help too as will RouterStats and its graphs.
Quote So don't worry about it.
I'll try not to.
