Solid orange light
Manny90
Solid orange light
Anyone managed to resolve this? Is it an issue my end or plusnets side? Been working fine last night then suddenly been off all day.
TIA
Tags (1)
55 REPLIES 55
Fixes: 387
Re: Solid orange light
Welcome to the forums, @Manny90 . First question - is your phone line clear? Dial 17070, preferably from a corded phone, and after your number is confirmed, select option 2, the Quiet Line Test (QLT) The line should be silent apart from the regular 'Quiet Line Test' announcement. Any noise, report a phone fault. No noise, come back here for further guidance.
Manny90
Thanks John. Unfortunately I don’t have a landline phone to test the dial tone. We literally only use the internet. Everything was fine last night and nothing has been touched our end. Then suddenly no internet all day since I woke up this morning.
Fixes: 387
OK, @Manny90 , that does mean a little bit of extra investigation, and unfortunately, I doubt there will be any PN Help Team staff on until Tuesday. Which Hub do you have - Hub1 or 2?
Try pushing a paper-clip or similar into the rest hole on the rear of the Hub and holding the switch closed for 30 seconds or so and report the result. It is going to be a process of elimination.
As a point of interest, a cheap (~£10 or less) phone is an essential tool until everyone has FTTP.
Manny90
Panicking now as I have work to do. What a nightmare, typical this happens out of nowhere on a bank holiday.
Thanks, tried the factory reset and the light goes green, flashes orange then stays orange sadly Sad we have hub 2.
Fixes: 387
OK, that sounds like you have lost your PPP connection to the network, which will need PN intervention. As a further attempt to try and sort this, can you somehow post screenshots or photos of the 'Broadband' and 'Technical' pages from your Hub, as shown below?
Please obscure any personal details.
Manny90
Thanks, silly question but how would I get to these pages? Appreciate the help.
Fixes: 387
Not a silly question if you've never done it before. You need to log into the Hub management system by entering the details as printed on the pull-out card that comes with the Hub, and then navigating to them - should be fairly simple once you get the first screen up, but if you have difficulty, come back and ask - I'll be here until around 8.30PM
Fixes: 1,495
Open http://192.168.1.254 and follow @jab1 instructions above
Manny90
Thanks. Managed to get this up eventually. Not sure what was personal so please let me know if I’ve blocked too much. I can’t find a way to attach the images on this forum? They’re on my profile public gallery if you can view them there?
https://i.imgur.com/X3c1yVY.jpg
https://i.imgur.com/ItA7arV.jpg
https://i.imgur.com/KCUEhID.jpg
https://i.imgur.com/TDsTUSp.jpg
Fixes: 387
to insert the images, click the symbol between the 'smiley' and 'camera' on the row above the text box and follow the prompts. If you are using a phone/tablet, you may need to 'request desktop site' to see them.
Fixes: 1,495
Images can be seen here https://community.plus.net/t5/media/gallerypage/user-id/111243/tab/all
Manny90
Thanks. Yeah using mobile so can’t find the option. I’ve added the links above too externally if easier.
Fixes: 387
Thanks, @dvorak .
@Manny90 You appear to be totally disconnected. Probably a wild goose chase, but have you checked all your cables and plugs?
Manny90
It’s a strange one. Yeah all cables intact. I only have the filter cable in to the main socket on the wall and then the cable to the modem. Only me and my partner live here so no one’s touched anything 😕
