Smart Hub 2
vdubgirlmk4
Smart Hub 2
Help!
My router will not connect to my MacBook Air Wi-Fi at all. Any suggestions? Driving me crazy!
27 REPLIES 27
willcutforth
Fixes: 113
Re: Smart Hub 2
Hey there @vdubgirlmk4 and welcome to the forum!
That's frustrating, which router are you using?
 Will Cutforth
vdubgirlmk4
Re: Smart Hub 2
It’s the Smart Hub 2.
Fixes: 387
Re: Smart Hub 2
Has it connected previously? What, if any, error message do you see?
vdubgirlmk4
Re: Smart Hub 2
It’s a brand new router so it’s never connected to my laptop. Previous routers have and I can connect to my neighbours fine.
Fixes: 387
Re: Smart Hub 2
OK, so what happens when you enter the wireless password, after selecting your connection in the list of available networks?
Re: Smart Hub 2
@vdubgirlmk4
Also, how are you posting to this forum?
ie computer connected to the Hub2 by cable; phone or tablet connected by WiFi to the Hub2, or by mobile phone data etc etc?
vdubgirlmk4
Re: Smart Hub 2
I’m connect to the Wi-Fi on my phone, iPads, sky, fire sticks. It’s just the laptop.
When I try to connect on the laptop it buffers and then says it’s failed to connect run diagnostics.
vdubgirlmk4
Re: Smart Hub 2
It tries to connect (buffers) then says connection failed run diagnostics or try again.
Re: Smart Hub 2
@vdubgirlmk4
Have you tried rebooting the MacBook?
Fixes: 387
Re: Smart Hub 2
Or running diagnostics, as suggested?
vdubgirlmk4
Re: Smart Hub 2
Yes and the router.
vdubgirlmk4
Re: Smart Hub 2
Yes I’ve done that but it wasn’t helpful.
The settings on the smart hub 2 are quite limited too.
Re: Smart Hub 2
@vdubgirlmk4
Have you tried deleting the saved connection, (to your Hub2), on the MacBook, and re-establishing it?
Fixes: 387
Re: Smart Hub 2
To be honest, if your other devices connect OK, it is something on the MacBook which is causing the issue - nothing tom do with the Hub.
