Slow wifi. Webex video calls keep dropping and sound. Not enough bandwidth?
- Re: Slow wifi. Webex video calls keep dropping and...
15-06-2021 8:44 PM
Hi
I'm having issues with my wifi and webex. I can't seem to have a normal call without the call dropping out. 'Low bandwidth it says'
Audio only seems to work better than video but both dropping out.
I have changed my wifi channel to 11 (best channel in my area) and it still doesn't work.
I never used to have problems with ADSL on Sky.
What can I do?
Re: Slow wifi. Webex video calls keep dropping and sound. Not enough bandwidth?
16-06-2021 1:20 AM - edited 16-06-2021 1:39 AM
I should add that the router is a free one from plusnet. It only has 2ghz option and my wifi has been v. slow ever since I joined.
Really need a fix urgently.
Others seem to have the same issue: https://community.plus.net/t5/My-Router/WiFi-keeps-dropping-out-Hub-Zero/m-p/1812614
Report:
<a href="http://www.dslreports.com/speedtest/68666696">
<img src="http://www.dslreports.com/speedtest/68666696.png"></a>
16-06-2021 10:58 AM
Good morning @ar533
Thank you for reaching out via our Community Forum.
So after running some tests on my end, it does appear that the line is operating correctly and within estimated line speeds. Can I ask whether you're experiencing the same issues with other applications? As you can imagine, it's often tricky to diagnose wireless issues as the factors which determine the strength and consistency of your wireless connection are outside of our domain.
These include things such as the number of other devices connected, electrical interference, the demographics of your property etc.
further information on how to establish the best wireless connection within the property can be found here: https://www.plus.net/help/broadband/getting-the-best-wifi-signal/
16-06-2021 11:18 AM - edited 16-06-2021 11:19 AM
Yes, also dropping out on my iPhone and connection drops on my other laptop,
Can the router can't cope with the buffer bloat?
The router does seem v. basic and is one provided 2 year ago I believe.
It should be able to cope with iPhone and 3 laptops connected.
16-06-2021 11:42 AM
Hi @ar533
It's all subjective really, and depends on the amount of data being transferred by specific applications at any given time, so this definitely could be the case. going forward though, I've just processed an upgraded router (Plusnet Hub One) to be sent out to you, arriving within 3-5 working days
This should improve your overall connection. I've also found that Fibre is available on your line, which would be another option if you continue to encounter further issues.
22-06-2021 9:07 AM
Might we be missing simpler issues here?
What is your line capable of and is it "clean"?
What are the expectations for your line?
Please use the following links to check the services available and their estimated speeds. From the first link, please record and report back the distance from the exchange. The second link advises of which fibre services (if any) are available on your line and their anticipated speed.
Broadband is not going to work well if the "phone" line is not working properly.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below. From the Q&A list, choose the one which matches the problem, 'open' the 'section' and click the trouble-shooter link. NB: If you receive a failure message (rather than a log-in prompt) then log-in to the user portal in a different browser tab and attempt to use the trouble-shooter again.
How is your line performing?
Please post your router stats; for PN TG582n and 2704n routers use the buttons below, for other routers look at the Kitz link.
Also run a BT Wholesale speed test (ideally using an Ethernet wired PC with the WiFi turned off) then run the further diagnostics and post the results here. DO NOT REBOOT the router!
NB: Please use an Edge browser or IE as there have been many reports that others fail to function correctly when accessing the BTw speed test.
