Slow upload
- Re: Slow upload
Re: Slow upload
03-11-2011 10:46 AM
Jojo
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Re: Slow upload
04-11-2011 8:13 AM
![Embarrassed Embarrassed](/html/@6CEFBAD878A40FF337662307A879A7FD/images/emoticons/embarrassed.gif)
I have this thomson router TG585 V8, could this be the cause? The line in my flat has been connected by BT openreach but sometimes when I'm on the telephone there is some 'noise'. I'm currently using the router without a telephone connected. Just router - microfilter - main socket in flat.
My result is here:
![](http://www.speedtest.net/result/1572644753.png)
Thank you!
Re: Slow upload
04-11-2011 8:18 AM
That upload is normal for the way your line is set up. I can uncap that for you so you'll get more in the region of 900K. I'll place the order now and this should take effect on Monday.
Jojo
Re: Slow upload
04-11-2011 8:22 AM
Re: Slow upload
04-11-2011 8:28 AM
Re: Slow upload
04-11-2011 10:17 AM
![Cheesy Cheesy](/html/@69488338D0B3891CC5F8AEAEEB30C648/images/emoticons/cheesy.gif)
Re: Slow upload
05-11-2011 12:46 PM
Quote from: Joanne Hi Leeheyes,
we have had an issue with wireless uploads with certain router/computer combinations.
Jojo
Jojo - is this a permanent slowness or one that comes and goes. My V8 router (shipped to fix issues I was having with my V7) shows this problem but it goes away for a bit when I reboot it. I've got my V7 acting as a secondary wireless connection and if I connect via that I get startling different results:
[tt]Date Download Speed Upload Speed
Today 12:42 2358 kbps (295kB/s) 374 kbps (46.8kB/s) Share
Today 12:40 2512 kbps (314kB/s) 112 kbps (14kB/s) Share
[/tt]
The top one (374) is via my V7 Router. The 112 is via the V8 router which is acting as the ADSL connection.
The V8 is running 8.2.7.8 and the two laptops are both running Intel Wireless cards (I can get specific model info if you need it).
Re: Slow upload
07-11-2011 10:57 AM
I would say, from this and the Thomson router thread, that it seems to be a combination of constant slow upload and those who report it as something that deteriorates over time.
Jojo
Re: Slow upload
09-11-2011 10:49 AM
I restarted it and the upload is still lousy using wireless:
Today 10:43 2346 kbps (293kB/s) 346 kbps (43.3kB/s) Share
Today 10:42 2546 kbps (318kB/s) 138 kbps (17.3kB/s) Share
Today 10:40 2383 kbps (298kB/s) 157 kbps (19.6kB/s) Share
Today 10:37 2352 kbps (294kB/s) 128 kbps (16kB/s) Share
Today 10:33 2361 kbps (295kB/s) 151 kbps (18.9kB/s) Share
(the top one being my V7 which acts as a secondary wireless access point).
Re: Slow upload
09-11-2011 3:08 PM
would you like me to try and arrange to get you another v7?
Jojo
Re: Slow upload
09-11-2011 6:50 PM
Re: Slow upload
10-11-2011 8:25 AM
Re: Slow upload
14-11-2011 9:32 PM
![](http://www.speedtest.net/result/1592191878.png)
This was a good result, most times it's much lower than that
I also did the bt speedtest tonight too. This is now starting to effect how I can use the internet. Uploads are failing due to the low speed. What can be done?
Uptime: 0 days, 2:28:29
DSL Type: G.992.1 annex A
Channel mode: Fast
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,112 / 8,128
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 164.31
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 15.0 / 27.5
SN Margin (Up/Down) [dB]: 25.0 / 7.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Signal (Local/Remote): 131,074 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 131,074 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 77
HEC Errors (Up/Down): 0 / 925
Re: Slow upload
14-11-2011 9:33 PM
Re: Slow upload
14-11-2011 9:42 PM
