Slow throughput
- Slow throughput
Slow throughput
27-08-2009 5:13 PM
For a few days now, I've noticed that the throughput speed isn't exactly what i'm used to on my somewhat slow anyway line.
I finally got round to testing it with the BT tester today:
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 3068 kbps(DOWN-STREAM), 952 kbps(UP-STREAM)
IP profile for your line is - 2500 kbps
Actual IP throughput achieved during the test was - 740 kbps
MyBroadbandSpeed agrees with this sad state of affairs.
On ADSL Max I used to sync at 3500, but 2+ has eventually settled on 2500, having toyed with 4500 when I started, and going via the occasional 3500.
Has the DLM decided it doesn't like me?
Re: Slow throughput
27-08-2009 8:25 PM
Plusnet Technology
Re: Slow throughput
28-08-2009 8:05 AM
Usertools doesn't show any capacity problems for my exchange (Worcester Central) but I guess 21CN is a different beast?
I'll test it again this evening.
Alex
Re: Slow throughput
28-08-2009 11:11 AM
Cheers,
Jon
Re: Slow throughput
28-08-2009 11:13 AM
I'll get something posted when we've got further details.
Re: Slow throughput
28-08-2009 5:54 PM
Re: Slow throughput
29-08-2009 3:38 AM
Re: Slow throughput
01-09-2009 7:56 PM
Is there some maintenance due that would affect throughput on the 21CN down to the Worcester Central exchange?
And to echo the comments of other users, given the relatively small numbers of users on 21CN at the moment, is this product ready to be rolled out at all - if the problem lies with BT, surely their infinitely fast network just isn't ready for customers yet? Unless the limit is from the (understandably) limited amount of capacity on the PN trial?
Alex
Re: Slow throughput
02-09-2009 7:46 AM
i belive the capicty will be the same now as it was then as spotify still runs perfect on 21cn if capicty was tight on 21cn i would susspect spotifys p2p traffic to be effected just as it is on 20cn.
all i can say is ive been getting jumpy throughput at times since BTw did some matince work on the sheffield node a couple of weeks ago
Re: Slow throughput
02-09-2009 8:42 AM
I'll check with Dave.
Re: Slow throughput
04-09-2009 9:48 AM
What is happening? I know its a trial but we are still paying for a service and at the moment I cant use it.
John B.
Re: Slow throughput
04-09-2009 9:51 AM
Do you see the same when you reboot?
Re: Slow throughput
04-09-2009 10:18 AM
Due to the idiosyncrasies of ADSL2+ I try to avoid re-booting when possible, these readings are following a re-boot and are an improvement on what I was getting earlier this morning.
I have now just re-booted again and things have returned to normal. Following a disastrous nine weeks of slow speeds etc. I am very wary of even touching the router let alone re-booting it.
Let’s hope that things will settle down and remain stable.
John B.
Re: Slow throughput
07-09-2009 9:54 PM
The BTSpeedtest results are:
Download speedachieved during the test was - 5729 Kbps
Additional Information:
Your DSL Connection Rate :9536 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 8000 Kbps
Is the IP Profile correct @ 8000?
When I first transferred over, I was connected at 11K +
Re: Slow throughput
08-09-2009 12:32 PM
There doesn't appear to be anything wrong with those speed results at all to be honest with you.
I've double checked and we're also profiling your line at the correct speed.
