Slow speeds
- Slow speeds
Re: Slow speeds
30-04-2012 4:53 PM
Re: Slow speeds
30-04-2012 5:04 PM
Re: Slow speeds
30-04-2012 5:13 PM
So as it stands... the blue wires are connected into the back. and they stop there. The green and orange wires aren't connected at all. As if they weren't connected to anything ever (plastic hasn't been peeled/cut back). Are the green ones meant to be connected to 2 and 5? You said the blue ones were meant to be but they are connected else where. Do i risk re-wiring this?
Thanks for the help btw
Downstream Upstream
Data Rate(Kbps)
5792 448
Noise margin (dB) 16.1 21.0
Output power (dBm) 11.9 19.7
Attenuation (dB) 20.0 11.0
The adsl stats seem similar to what they were before.
Just to clarify, the blue wires are connected into the A and B within the back plate and there are no extra wires except for the 2 blue 2 green and 2 orange like you stated.
Re: Slow speeds
30-04-2012 5:21 PM
Quote from: phlim If i make it less awkward and keep the router plugged into the test socket from now on, after 10 days or so it will resume back to normal?
It should do, yes. Unfortunately though if you then move the router once everything's back to normal again it'll break, because you'll put it back onto your internal wiring.
Quote from: phlim By plugging it into an extension cable does this count as plugging it into an extension socket?
Essentially yes I'm afraid. I've heard you can get proper shielded extension wiring but then if you're doing that it makes much more sense to use a longer ethernet cable and leave the router in the master (or test) socket. You can get a 20 - 25 metre length of ethernet cable for around £10 from ebay or amazon.
Quote from: phlim And finally, in relation to the first question. Can this not be resolved untill i fix my "internal wiring"?
Yes - provided you're willing to leave the front plate off all the time. Removing this disconnects the internal wiring, which is why using the test socket has fixed the problem. The moment you add the internal wiring back into the equation I suspect the problem will come back again.
Quote from: phlim I have no idea whats causing an issue on internal wiring. Will this mean I have to ring up BT to test the test socket for any internal wiring issues?
Nope - as I said above, using the test socket disconnects the internal wiring.
The best way to find out where the problem is would be to reconnect the front plate and see if the sync rate has dropped. If not, you're fine to use the master socket. Then, plug everything else back into the line, one thing at a time. Make sure you check the sync rate after each item is reconnected. It could be a dodgy filter or phone adding interference, so if you see a sudden drop in speed after connecting something chances are you've found your culprit.
If it's all okay then you could go back to using an extension socket if you really must, but the extension wiring is much more susceptible to errors and will almost certainly reduce the sync speed - plus if there are any issues in the future you'd need to move the router back down to the test socket again.
This is because BT will fix any issues on the wiring between the exchange and your premises up to and including the master socket, but anything inside of the master socket isn't included. If any faults are found there when an engineer attends then there's a chance you could be charged I'm afraid.
Hope that helps clear things up a bit.
Re: Slow speeds
30-04-2012 5:27 PM
Re: Slow speeds
30-04-2012 5:28 PM
Quote Ok, I'm looking at the back of the front plate and I can see the slots 1-6 with nothing in them! It was like this when i first took the plate off, and this was why i thought i was meant to be looking at the plate behind that.
If there are other telephone points in the property then there are three options
It isn't the master socket
The sockets are connected using star configuration from a centre junction box
The internal wiring is bodged
Re: Slow speeds
30-04-2012 5:29 PM
I'll post more in a moment when I've read Matt's post.
Re: Slow speeds
30-04-2012 5:30 PM
Re: Slow speeds
30-04-2012 5:41 PM
The whole point of being in the test socket is that under normal circumstances the internal wiring is disconnected just to be sure there is no problem with it, and this is where the modem/router should remain plugged in whilst tests and engineer visits are carried out as & when required.
Once an NTE5 master socket has been fitted, all internal wiring is the responsibility of the occupant/owner. BT charge one huge price for sorting internal wiring, it's best to do it yourself, it's not difficult. What you need to do is get a cheap plastic IDC tool from a store that sells telecoms stuff.
I'll post suggestions in a moment.
Re: Slow speeds
30-04-2012 5:49 PM
If you are prepared to do without your extension sockets for a short while, disconnect your ppp session, power down the modem/router.
Use the correct screwdriver on the A & B terminals to remove the Blue/white & White/blue extension wiring, just leaving the BT incoming cable connected.
Edit: If/once you have done that, whilst the modem/router is off, plug a corded phone into each of the "extension" sockets in turn and confirm they are all dead (no dial tone or other noises).
Re: Slow speeds
30-04-2012 5:58 PM
The strange thing about it all is that it appears to have been like this ever since we've been living here. No-one that i know of has changed it or even looked at it as they wouldn't know what's going on. It all went slow 2/3 days ago, before that it was all fine.
Re: Slow speeds
30-04-2012 6:09 PM
Re: Slow speeds
30-04-2012 6:10 PM
Re: Slow speeds
30-04-2012 6:12 PM
And no there are no other sockets in the property.
Re: Slow speeds
30-04-2012 6:21 PM
Edit: spelling
