Any way to cap my broadband speed on ADSL2? (over ambitious profiling!)
- Any way to cap my broadband speed on ADSL2? (over...
25-04-2012 7:50 PM
I then reboot my router and it gets a far more realistic profile. Is there any way to manually "cap" thew profile?
Re: Any way to cap my broadband speed on ADSL2? (over ambitious profiling!)
25-04-2012 8:36 PM
25-04-2012 8:41 PM
Does it matter? It's an annoyance that my broadband is useless until I reboot it again because of the silly profile it's given
25-04-2012 8:48 PM
25-04-2012 9:40 PM
25-04-2012 10:44 PM
Quote from: ClashcityRocker Because the builder needed fo turn the leccy off, because I updated the firmware, because of a powercut...
Yes it mattered, and as you may not understand how ADSL works, it could have been you rebooting because of line drops or some other fault affecting your noise margin. We don't know what modem/router you have, how old it is, or any line stats or BT speedtest results etc. Have you tried an alternative modem/router and filter at the Test Socket to try and eliminate those possibilities?
If you are wanting a profile to be fixed to some "nice" value, in fact any value, the short answer is no.
As you seem unwilling to give any information, you are probably best to raise a fault and wait for a member of the Plusnet team to look at your account rather than other forum members trying to assist you.
25-04-2012 10:59 PM
It's a draytek 2820, and the line is very stable (and always has been) except when the router is initially started, and it gets a totally unrealistic profile. I admit I don't know how these profiles are worked out, and what kind of history they have, but I know that my line is totally incapable of supporting 17715947, and the 1MB downloads from fast severs are taking over 3 hours to download and my router error rate is going bananas, yet when I restarted it gets 16854532 and the speed is brilliant and there is virtually no error packets.
25-04-2012 11:32 PM
I think what you are seeing is that very quickly - probably in the evening - the noise margin drops to about 1dB and the errors kill your connection.
A resync at that point will give a slightly lower speed with the 3dB noise margin.
The problem is probably related to the router (I have seen this before) hanging onto the connection and not resynching when the error rate is too high
If Plusnet manage to force the default noise margin to 6dB your speed will drop a lot more than 1,000kbps
25-04-2012 11:36 PM
If you have the latest firmware (a quick cursory search indicated it fixed a few bugs - didn't look at the detail) then I'd go for trying another modem/router and filter just to test if the same occurs.
It might be worth you posting the Modem/Router Line Stats from when it's ok and then again next time it isn't to see if the differences reveal anything.
Edit: add thread link
26-04-2012 9:33 PM
Current GOOD are:
--------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
Running Mode : ADSL2+(G.992.5) State : SHOWTIME
DS Actual Rate : 16997087 bps US Actual Rate : 888888 bps
DS Attainable Rate : 18592000 bps US Attainable Rate : 888000 bps
DS Path Mode : Interleave US Path Mode : Interleave
DS Interleave Depth : 96 US Interleave Depth : 8
NE Current Attenuation : 27 dB Cur SNR Margin : 3 dB
DS actual PSD : 20. 3 dB US actual PSD : 11. 8 dB
ADSL Firmware Version : 2471201_A
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 15 dB Far SNR Margin : 13 dB
CO ITU Version[0] : 00004946 CO ITU Version[1] : 0000544e
DSLAM CHIPSET VENDOR : < IFTN >
I will wait for it to go wrong again, and repeat the above.
26-04-2012 9:44 PM
10-05-2012 6:03 PM
Router Stats: (note the higher than normal sync speed)
DS Actual Rate : 17539622 bps US Actual Rate : 888888 bps
DS Attainable Rate : 17192000 bps US Attainable Rate : 888000 bps
DS Interleave Depth : 320 US Interleave Depth : 8
NE Current Attenuation : 32 dB Cur SNR Margin : 2 dB
DS actual PSD : 20. 2 dB US actual PSD : 12. 3 dB
ADSL Firmware Version : 232201_A
Far Current Attenuation : 15 dB Far SNR Margin : 14 dB
Speed test:
Going to reboot the router, and pretty sure it will get something that's a MUCH better sync rate, and something that instantly improves my speeds.
10-05-2012 6:09 PM
DS Actual Rate : 17115947 bps US Actual Rate : 888888 bps
DS Attainable Rate : 17152000 bps US Attainable Rate : 888000 bps
NE Current Attenuation : 32 dB Cur SNR Margin : 3 dB
DS actual PSD : 20. 1 dB US actual PSD : 11. 7 dB
10-05-2012 6:11 PM
11-05-2012 4:19 PM
