Slow speeds
- Slow speeds
Re: Slow speeds
01-05-2012 4:24 PM
Re: Slow speeds
04-05-2012 2:26 PM
Phil x
Re: Slow speeds
04-05-2012 4:41 PM
We could probably get it a bit faster. Your SNR is 15dB, probably following the fault. If I set this to 6dB you'd probably get a higher speed. It would start a new 10 day training period though. Would you like me to do it?
Jojo
Re: Slow speeds
04-05-2012 6:10 PM
what happens/do i have to do during this 10 day training period? and how much faster will this make my speed? At the moment i'm happy with the speed i have and am capable of getting, but if it's not too much trouble i might be interested in this.
Re: Slow speeds
04-05-2012 7:43 PM
Re: Slow speeds
04-05-2012 8:37 PM
Downstream Upstream
Data Rate(Kbps) 6016 448
Noise margin (dB) 15.4 18.0
Output power (dBm) 11.6 19.7
Attenuation (dB) 20.0 11.0
Re: Slow speeds
04-05-2012 9:07 PM
You really should be able to sync at 8128 if the line is stable so interleaving can be turned off, the later giving much better latency if you are a gamer, so yes worth trying an SNR reset if the error rate isn't high.
Re: Slow speeds
05-05-2012 12:29 PM
Re: Slow speeds
05-05-2012 3:55 PM
Re: Slow speeds
07-05-2012 12:50 PM
Re: Slow speeds
09-05-2012 10:06 AM
Re: Slow speeds
09-05-2012 2:36 PM
Just tried looking at your line and as you're out of sync there's not much I can do at the moment. Let us know when you're connected again and I'll take a look.
Jojo
Re: Slow speeds
09-05-2012 10:54 PM
Re: Slow speeds
10-05-2012 9:21 AM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13366379925022.png" />
Quote I'll be plugged straight into the socket with my laptop hopefully on Friday.
I'm assuming you mean the master socket or the test socket (latter being preferable if there is one)
Let us know when you are so we can test the line again.
Re: Slow speeds
11-05-2012 11:35 AM
Data Rate(Kbps) 6080 448
Noise margin (dB) 14.0 24.0
Output power (dBm) 11.9 19.7
Attenuation (dB) 19.0 11.0
Those are my stats. I'm currently connected into the main socket the speeds are pretty dire (same as before)
Download speedachieved during the test was - 0.09 Mbps
For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps.
Additional Information:
Your DSL Connection Rate :6.08 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.14 Mbps
We replaced a cable which i believe should have stopped all the constant disconnections (some old wire). And since then we have had these slow speeds. I'm guessing I should just leave it be for a couple/3days and see if it sorts itself out like last time?
