Slow speeds after joining plusnet
- Re: Slow speeds after joining plusnet
16-05-2014 6:26 PM
Quote from: iqb043 I was initially on evening and weekends but was advised i would need the anytime package to add the broadband.
Was that advised by PlusNet or does that statement relate to your previous supplier?
You do not need to have a phone line package to have PlusNet broadband, it is though cheaper if you do have your phone line with PN. There is also no need for you to have a call pack bundled into the deal either. For example, if you opt for line rental saver (LRS) then there are no included calls at all, unless you opt for that package extension.
16-05-2014 6:32 PM
Whats this call back feature and how much is it? I havent requested anything like that.
I got an email this afternoon stating the phone line is set up
16-05-2014 6:38 PM
Quote from: iqb043 Its disconnected a number of times which has led to a really low sync speed with high snr margin.
The upload speed is still capped and im not sure if interleaving is turned off.
The output power for the download is 0db as well for some reason. The firmwares on 10.2.5.2 and im using the modem from my previous supplier (Be). Could that be an issue?
Can you be sure that the disconnections have lead to the SNRM being so high as opposed to there having been interference at the time the router synched up and now the noise has gone, the SNRM has risen accordingly. It would be useful to download and install routerstats to monitor SNRM.
Interleaving is on and given the way the line is performing it might be necessary!
Do not worry DS output power, that is not something the router can measure.
16-05-2014 6:49 PM
The snr was 6 a few days ago? Then i saw 12 and now 15
16-05-2014 6:54 PM
Quote from: iqb043 The snr was 6 a few days ago? Then i saw 12 and now 15
That is interesting up to a point - without the other bit of information - synch speed - it is not possible to know if the changed SNRM is down to a resynch at a lower speed or if there has been no resynch but interference has gone away.
The only way to get a clear picture on interference is to run constant monitoring using something like routerstats.
The sources of interference are many and might not even be within your own home. Today, one person on this forum discovered that their interference was coming from a neighbour's Freeview Box.
Have you followed all of the guidance on the speed issues thread at the top of this forum?
16-05-2014 9:29 PM
These are the modem sync speeds
19-05-2014 10:50 AM
I would suggest raising a fault here: http://faults.plus.net
Our Faults team can then investigate this for you and provide you with updates.
19-05-2014 10:52 AM
19-05-2014 11:12 AM
19-05-2014 11:41 AM
19-05-2014 1:27 PM
This means that DLM should make the necessary changes for you. At the moment, your Line Quality is still showing as 'Red' so it's not going to make any positive changes until DLM has seen your line error free for a day or so.
19-05-2014 2:12 PM
22-05-2014 6:19 PM
I dont want anything changing atm if the line is still training
23-05-2014 7:36 AM
Recieved this email this morning to
When you signed up for your broadband account, we performed a check on your telephone line to give you an estimated speed your line might achieve.
Now that your service has now been active for 14 days, we thought we'd let you know the speed as it stands today, by way of comparison.
Estimated line speed: 11.5Mbps
Current line speed: 6.8Mbps
You can keep a track of your line speed through our website:
No where near
23-05-2014 9:03 AM
Your line quality has improved from Amber to Green, so DLM will now be looking to reduce the SNR Target.
