Slow speed
- Slow speed
Re: Slow speed
05-05-2012 8:53 PM
DSL Connection
Link Information
Uptime: 0 days, 1:08:55
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,200 / 2,268
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 14.5 / 25.0
SN Margin (Up/Down) [dB]: 6.0 / 19.5
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 2 / 0
FEC Errors (Up/Down): NA / 80
CRC Errors (Up/Down): NA / 0
HEC Errors (Up/Down): 0 / 0
latest says loss of signal is that plusnet messing?
Re: Slow speed
05-05-2012 9:15 PM
Why don't you upload them here using the Additional Options and Attachments button when composing a post
Re: Slow speed
05-05-2012 9:23 PM
Quote from: Oldjim I don't know about anyone else but I can't access the pictures.
done fella didnt notice the option/button lol back on the beers
Re: Slow speed
05-05-2012 9:23 PM
Re: Slow speed
05-05-2012 10:59 PM
Anyway, try and answer the questions tonight, but if you've had a few beers, we'll leave anything else until the morning
Has the modem/router been off, and switched on around 7.45 pm.?
I see BT has some wonderful wiring (not) at that first incoming connection box not that it's going to make any difference, and you have one fixed extension socket, do you know if the bell wire had been dealt with?
(I'm hoping Chris Pettitt can post the latest Session Connection chart as well).
Re: Slow speed
05-05-2012 11:20 PM
Here we go, as promised.
Re: Slow speed
06-05-2012 12:00 AM
BooYar, are you vulnerable to mains drops where you are?
Otherwise I think we'll try and check out connections and the bell wire issue tomorrow as I suspect the score at the moment is Router 1, Beer - quite a few more.
Re: Slow speed
06-05-2012 1:13 AM
Re: Slow speed
06-05-2012 6:57 AM
Re: Slow speed
06-05-2012 1:13 PM
Regarding the Fault on your line, I would strongly advise for you to raise a Fault due to the issues that you are having with your line. I think it is important that our Faults Team take a look and investigate and we can then get the issue resolved for you.
I will raise a fault later or tomorrow as im off to a party!!
Thanks for all you help and advise Anotherone i hope this gets sorted soon o7
Re: Slow speed
06-05-2012 2:10 PM
Can you also post your latest stats.
You should have a test socket as the second photo (IMAG0175) is showing a BT Master NTE5 Socket.
I also refer you back to the first paragraph of my reply #16.
I still think you should be de-Banded as the error rate is so low and there has only been one disconnection in over 24 hours, in fact since last Monday. Your remarks in reply #4 are especially pertinent to what has happened to your line.
But, Your priority has to be checking and tidying up your internal stuff first as in the first instance you will be told by faults to connect to the Test socket, so we might as well get that checked out now.
Who do you pay your telephone line rental to? (not your broadband).
Re: Slow speed
06-05-2012 6:33 PM
Re: Slow speed
07-05-2012 12:23 PM
DSL Connection
Link Information
Uptime: 1 day, 3:58:02
Bandwidth (Up/Down) [kbps/kbps]: 1,191 / 2,272
SN Margin (Up/Down) [dB]: 6.0 / 30.0
Loss of Framing (Local/Remote): 22 / 0
Loss of Signal (Local/Remote): 3 / 0
Error Seconds (Local/Remote): 3 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 46
HEC Errors (Up/Down): 0 / 30
I must put my hand up and apologise for saying i don't have a test socket.. I took the cover off and there you go a test socket. I'm sure i removed this b4 and never noticed the test socket..
I need a cable that is long enough to reach modem to test socket now :E
This week im working 1400-2200hr shift so my hours of internet activity will vary
Re: Slow speed
07-05-2012 3:12 PM
I'm afraid a "cable that is long enough to reach modem to test socket" is not the way to go. When/if it comes to it, the filter must be plugged directly into the test socket and the mode/router into the filter with it's own short lead. Long leads will pick up interference and negate the testing.
But we may not need to go that far.
The stats you've posted are good, you've had a solid connection there for 28hrs as far as I can tell, but to be sure were those stats before you looked for the test socket?
Please remember when doing anything where you may lose sync or need to disconnect/swap follow this procedure -
Login to the modem/router interface and click on the "Disconnect" button - this terminates the "ppp" session to the ISP (not sync to the exchange). Wait a good minute after the button changes to "Connect" (refresh the page to be sure).
Then power down the modem/router. Wait a good minute before unplugging the modem/router or it's filter from the line. Then swap whatever needs to be swapped.
Wait another 10 minutes before powering up again.
Re: Slow speed
07-05-2012 6:54 PM
