Slow speed (IP profile 135K, but modem sync is 2-3Mbps)
- Slow speed (IP profile 135K, but modem sync is 2-3...
Re: Slow speed (IP profile 135K, but modem sync is 2-3Mbps)
05-08-2011 9:37 AM
Stats for Thomson :
Uptime: 0 days, 0:06:09
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 944 / 3,584
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,520
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 1.00
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 27.0 / 50.0
SN Margin (Up/Down) [dB]: 21.0 / 8.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 18,411
CRC Errors (Up/Down): 0 / 32
HEC Errors (Up/Down): 1 / 349
Adam
05-08-2011 2:43 PM
I've just lifted your profile to 3500 so you should see the increase in the next 15 minutes.
Jojo
05-08-2011 4:16 PM
Download speedachieved during the test was - 2797 Kbps
Additional Information:
Your DSL Connection Rate :3520 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 3500 Kbps
A marked improvement, I was just seeing 360KB/s on an update to Steam.
05-08-2011 4:37 PM
05-08-2011 6:19 PM
If it stays like this I'll be as happy as a ginger person has any right to feel
Adam
06-08-2011 8:30 AM
Download speed achieved during the test was - 3045 Kbps
06-08-2011 12:10 PM
12:07pm 6th August 2011
Download speedachieved during the test was - 824 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
IP Profile for your line is - 1000 Kbps
06-08-2011 2:10 PM
06-08-2011 6:01 PM
Link Information
Uptime: 0 days, 1:44:14
Maximum Bandwidth (Up/Down) [kbps/kbps]: 928 / 2,272
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,240
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 448.00
Line Attenuation (Up/Down) [dB]: 27.5 / 50.5
SN Margin (Up/Down) [dB]: 21.0 / 10.0
Loss of Framing (Local/Remote): 74 / 0
Loss of Signal (Local/Remote): 262,143 / 0
Error Seconds (Local/Remote): 262,155 / 0
FEC Errors (Up/Down): 8 / 43,989
CRC Errors (Up/Down): 7 / 48
HEC Errors (Up/Down): 1 / 229
17:57pm 6th August 2011
Download speed achieved during the test was - 834 Kbps
Your DSL Connection Rate :2240 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
06-08-2011 10:55 PM
Uptime: 0 days, 1:28:12
Maximum Bandwidth (Up/Down) [kbps/kbps]: 920 / 3,136
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,136
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 699.00
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 27.0 / 49.5
SN Margin (Up/Down) [dB]: 21.0 / 4.5
Loss of Signal (Local/Remote): 327,678 / 0
Error Seconds (Local/Remote): 327,728 / 0
FEC Errors (Up/Down): 0 / 839,750
CRC Errors (Up/Down): 0 / 13
HEC Errors (Up/Down): 0 / NA
BT Speedchecker would not run
08-08-2011 2:35 PM
I'll chase the fault as a line fault with my current Phone provider (Orange) and see where I get to.
Still running at a usable 170KB/s this morning, so far better than the 0.3mbps I was suffering a while back.
Adam
08-08-2011 4:00 PM
I've given your line the once over. We can see that the connection is dropping out and the line speed is fluctuating wildly which is why the IP profile has also been fluctuating. See the last 7 days below:
Whilst there is a telephone fault open against your circuit we cannot investigate a broadband issue. Please let us know the outcome of your open telephone problem with Orange and let us know if you need us to investigate further.
17-08-2011 7:11 AM
Download speedachieved during the test was - 120 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Your DSL Connection Rate :160 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
BT Engineer coming this morning.
17-08-2011 11:17 AM
In short, the BT guys have been and worked on the above-ground sections of the line. The line sounds clear and the modem has sync'd at 3232K, but I'm currently stuck on 135K IP Profile.
Can you ask for a retrain on the line or are we stuck with a 72 hour wait until we know if they've fixed the fault?
Adam
17-08-2011 4:31 PM
It's definitely better to wait and confirm the line is stable, you might accelerate the profile uplift by resyncing once a day around lunchtime (if you disconnect via the router's interface before powering off and on again it won't be seen as a forced disconnect by the exchange) though if it hasn't uplifted within a couple of days then we'll definitely reset the SNR for you.
Hope that helps,
