Slow internet
Sug12340
Slow internet
Why on most evenings my internet speed goes from over 50mbps to about 17mbps not happy when I’m paying for over 50mbps
4 REPLIES 4
Fixes: 480
Re: Slow internet
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
RealAleMadrid
Fixes: 68
Re: Slow internet
@Gel @The information in your link is outdated and not relevant to FTTC connections. If the OP has consistent slowdowns at peak times which is unusual on FTTC a possible cause is congestion in the backhaul at the exchange known as a hot VLAN. The problem is Openreach will never admit it without a lot of pressure from Plusnet.
@Sug12340  What are you speeds like early in the day and what are your router sync speeds, from the diagnostics page on your Hub or whatever router you are using?
Fixes: 1,663
Re: Slow internet
I'm really sorry to see you're having speed issues.
If you can PM me your account username, I'll be happy to take a look at that for you.
