Slow download speed
Troypowell42
Slow download speed
I've been contracted for little under two years and my mbps is significantly lower than I'm guaranteed
4 REPLIES 4
Fixes: 357
Re: Slow download speed
A little more detail would help us to help you. What is you minimum guaranteed speed, what are getting (over WiFi or Ethernet)?
Troypowell42
I use the Ethernet cable and I receive on average 7 mbps however my contract is for a guaranteed minimum of 36mbps
Fixes: 357
OK - you have a fault - contact Customer Support tomorrow (0330 123 9123)
James30
Fixes: 32
@Troypowell42  Hi, before we get stuck in can you reboot the router and test the speed with an ethernet cable because your router has experienced a reboot for at least 37 days?
If issues persist can you send in a picture of the back of the router and phone socket please or we can ring you to go through everything in one go.
James - Plusnet Sheffield
