Slow broadband
- Re: Slow broadband
Slow broadband
18-02-2011 12:51 PM
Yesterday my broadband slowed down to 86Kbps and was like this all day. I tried to go through the steps PlusNet recommend but unfortunately I do not have a spare router and cannot access one.
This morning my speeds were fine, but they have deteriorated again, down to 486Kbps. I logged into the router and did a connectivity check on the Internet and I got a big red X for the Internet:
I have checked the connectivity a few times and sometimes everything is green and working, and other times I get the same result as the image above. Can someone advise what I can do to resolve this without the need to check with another router.
Message 1 of 4
(1,089 Views)
3 REPLIES 3
Re: Slow broadband
18-02-2011 1:00 PM
I've just done a traceroute for community.plus.net if this helps:
concepts:~ macuser$ traceroute community.plus.net
traceroute: Warning: community.plus.net has multiple addresses; using 212.159.8.110
traceroute to community.plus.net (212.159.8.110), 64 hops max, 40 byte packets
1 dsldevice (192.168.1.254) 7.768 ms 99.702 ms 99.878 ms
2 lo0-central3.pcl-ag01.plus.net (195.166.128.234) 47.232 ms 47.039 ms 50.845 ms
3 gi1-5-131.pcl-gw01.plus.net (84.92.6.16) 46.302 ms 46.637 ms 45.898 ms
4 po4.pcl-gw02.plus.net (212.159.1.129) 60.336 ms 62.171 ms 308.444 ms
5 te2-2.thn-gw2.plus.net (212.159.0.190) 59.594 ms 60.324 ms 59.283 ms
6 po4.thn-gw1.plus.net (212.159.1.134) 60.922 ms 58.855 ms 59.315 ms
7 po6.ptn-gw01.plus.net (212.159.1.137) 59.760 ms 60.543 ms 60.854 ms
8 gi3-0.pih-cr1.plus.net (212.159.1.177) 60.547 ms 59.785 ms 62.807 ms
9 if25.pih-lb03.plus.net (212.159.0.17) 61.538 ms 61.536 ms 62.404 ms
10 if25.pih-lb03.plus.net (212.159.0.17) 61.855 ms 59.548 ms 59.793 ms
Message 2 of 4
(320 Views)
Re: Slow broadband
19-02-2011 4:23 PM
Hi mentalist3d,
Both BT & our profile shows 7150k so I can't see anything obvious. Have a look here for some tips to troubleshoot the problem.
Jojo
Jojo
Message 3 of 4
(320 Views)
Re: Slow broadband
20-02-2011 1:04 AM
Hi Jojo
Thanks for the reply, I've had a look at that page and tested everything apart from the router (not got a spare) so I've submitted a ticket which is currently getting looked at, so hopefully it will be resolved soon or the problem identified.
Message 4 of 4
(320 Views)
