Re: Slow broadband
- Full Fibre
- Re: Slow broadband
Re: Slow broadband
an hour ago
Re: Slow broadband
53 minutes ago
@Michael16 You should really have started your own topic on the Full Fibre board - piggy-backing, especially on an old, fixed topic, is not good practice. I have asked for your post (and this reply) to be moved.
You say a refresh/reset helps. Are you using the PN Hub2? The speeds you are reporting (between 50-100) suggest that you are connecting to the 2.4, rather than 5Ghz band.
Re: Slow broadband
47 minutes ago
Thread moved from irrelevant topic on the Broadband board
Re: Slow broadband
32 minutes ago
Re: Slow broadband
31 minutes ago
Re: Slow broadband
21 minutes ago
I appreciate you are not happy, but please try and help us help you.
Can you please run wired a speed test on https://www.speedtest.net/ and attach the result to a reply.
It would also help us if you could attach your Hubs Status page and Technical Log - Information page, ensuring you obscure personal details.
