Slow broadband speed
raymondlan65
So according to Plusnet Hub Two manager I should be reaching 44Mbps, I usually receive 38Mbps. I know this is still slow, but that's how the cookie crumbles.
I've been experiencing slowdowns recently, so looking at the BT Wholesale basic speed test I am only receiving 10Mbps at best and 1Mbps at its worst. both checks were 20 seconds apart.
I never received a result after running the Plusnet Diagnostic Chatbot tests.
Any suggestions?
many thanks
1 REPLY 1
Fixes: 374
Re: Slow broadband speed
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one the only option is to call Plusnet - 0330 123 9123
