Slow Speed
- Re: Slow Speed
Re: Slow Speed
14-04-2009 7:45 AM
Re: Slow Speed
14-04-2009 7:58 AM
Re: Slow Speed
14-04-2009 11:46 AM
Hiya
Had an hospital appointment this morning so couldn't get photos done til now. If I could aviod having to lift the carpet for a new lead I rather but
it's not a great lose if I have to!!!!!!!
Here are the photos you requested
Regards
Re: Slow Speed
14-04-2009 12:03 PM
(and you should use "proper" twisted pair phone cable, not that awful flat stuff)
Re: Slow Speed
14-04-2009 12:53 PM
Even though the photos aren't too clear, they are IDC terminals (Insulation Displacement Connector). Hopefully they are still OK if you've been at them with your screwdriver
![Lips_are_sealed Lips_are_sealed](/html/@F9AC2D8C2C4C8B1A90221A46DDE6168E/images/emoticons/lipsrsealed.gif)
You need a little tool from B&Q, maybe PCworld, any telephony shop, Maplins etc. There are some very expensive ones around called Krone tools, but there are plastic ones available eg B&Q 40p or so. You don't need an expensive one. The generic name would be an IDC Insertion Tool.
In the meantime you can plug that 'Tamar' filter in at "the socket where you plug your sky in", taking stats as I explained yesterday. Then, you may as well powerdown the router for an hour say, and powerup before mid afternoon say, to recover that sync speed. I won't be able to post until later on today, so I'm hoping Pierre will be able to find you a few pictures of how to use the IDC Insertion tool - he' so good at finding info, and pictures like that
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
@HP this is the phone lead from the sky receiver, there's no real choice about the cable apart from which it'll be filtered.
Re: Slow Speed
14-04-2009 1:08 PM
Thanks for that information anotherone
Thses are the results for this morning, the 'Tamar' filter has been plugged into the extension socket (where sky adapter will go) since last night.
System Up Time 01:59:51
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 6992 7616 0 320 597 01:59:28
LAN 100M/Full 8233 14654 0 643 420 01:59:47
ADSL Link Downstream Upstream
Connection Speed 5024 kbps 448 kbps
Line Attenuation 36 db 8 db
Noise Margin 8 db 26 db
Regards Wattsy
Re: Slow Speed
14-04-2009 1:09 PM
Quote from: Anotherone @HP this is the phone lead from the sky receiver, there's no real choice about the cable apart from which it'll be filtered.
Understood that, but thought it had been extended (under the carpet?). Obviously the captive lead on the receiver isn't changeable.
Re: Slow Speed
14-04-2009 1:15 PM
Wattsy those stats are starting to look better, good luck with finding the tool, I've PM'd Pierre about pics. Speak to you later.
Re: Slow Speed
14-04-2009 1:29 PM
![](http://images.maplin.co.uk/300/bd41u_new.jpg)
Re: Slow Speed
14-04-2009 1:47 PM
![](http://www.super-smileys.com/images/smileys/499.gif)
![](http://www.super-smileys.com/images/smileys/799.gif)
Re: Slow Speed
14-04-2009 7:13 PM
Hiya
These results taken 5pm, router been disconnected throughout the afternoon
System Up Time 00:01:40
WAN PPPoA 364 651 0 798 3302 00:01:18
LAN 100M/Full 680 716 0 3518 1185 00:01:36
Connection Speed 4896 kbps 448 kbps
Noise Margin 8 db 24 db
These results are with the sky adapter plugged through the tamar filter
System Up Time 00:50:06
WAN PPPoA 2208 2507 0 166 571 00:49:44
LAN 100M/Full 2834 5499 0 621 263 00:50:02
Connection Speed 4768 kbps 448 kbps
Line Attenuation 37 db 8 db
Noise Margin 6 db 24 db
Now chaps, I don’t know how but I’ve managed to get the wires into the Sky adapter. Which I’m very pleased about, only problem is if I click
services on Sky it say phone not connected. But I’ve checked both ends of the sky cable, everything seems OK
Oh can I just say despite the better speed the web pages sometime are very slow to load.
Regards Wattsy
Re: Slow Speed
14-04-2009 7:22 PM
![Grin Grin](/html/@D40767E4EBB99989487344F3E42E44B1/images/emoticons/grin.gif)
Re: Slow Speed
14-04-2009 7:26 PM
Hiya
Yes I did have a quick look but I'll have another look after I had my tea, what did you think of the last lot of results??????
Regards Wattsy
Re: Slow Speed
14-04-2009 7:31 PM
![Embarrassed Embarrassed](/html/@6CEFBAD878A40FF337662307A879A7FD/images/emoticons/embarrassed.gif)
Re: Slow Speed
14-04-2009 7:35 PM
![Roll_eyes Roll_eyes](/html/@BA2C29EA5D62B3049244C6EF0F36F4A9/images/emoticons/rolleyes.gif)
