Slow Internet and Frequent Connection Drops Since Adding Phone Line
Lynnpin
Re: Slow Internet and Frequent Connection Drops Since Adding Phone Line
Thanks @Gandalf.
I would like to try a different router but so far I've had no luck in finding one so your offer to send a replacement would be much appreciated. I'm using the same old Thomson I've had for 8 years.
All the disconnections through the night have me baffled. Do you have any other ideas about what might be causing this?
Fixes: 1,601
It'll be difficult to advise what may be causing the issue as our testing isn't finding a cause.
I've ordered a replacement router now which you should receive within the next few days.
Let us know how it goes once you've got it and if you continue to see drops I'd then recommend raising a fault to us online.
Lynnpin
Thanks again @Gandalf
I hope the replacement router will solve this but I'll report back in a few days.
Fixes: 1,601
No problem. Fingers crossed!
Lynnpin
Hi @Gandalf,
Wow, that was fast! I received the replacement router today and I have it up and running.
Fingers crossed. I'll report back in a few days.
Thanks again.
Fixes: 1,601
The postie has done well! Thumbs_Up
Let us know how it goes.
Lynnpin
Hi @Gandalf
Sorry to report but I noticed last night around 12.30 a.m. that the broadband and internet lights were flashing on and off again. This 2704n router doesn't seem to have a built-in log like the old Thomson one so could you please post a revised chart as I don't know if this carried on through the night?
Fixes: 1,601
Hi @Lynnpin
That's disappointing, here's a log:
Things seem to have got a lot better, it may be worth checking back over the course of the next day or so.
Lynnpin
Thanks @Gandalf
It's not as bad as I thought so I'll leave it for a few days and report back.
Lynnpin
Sorry, forgot to say, is there no log on this new router?
Fixes: 1,601
I've had a nosey around in the router settings using a virtual app and it doesn't look like there is a log on this one. The most data seems to be on the Helpdesk tab but the uptime just shows how long the connection has been active for.
Unfortunately this is the router we'd send out for a standard broadband connection nowadays, we don't stock the Thomson or Technicolor routers anymore. Feel free to let us know over here if you're wanting a fresh log from our side.
Lynnpin
Will do, thanks @Gandalf
Lynnpin
Hello again @Gandalf
I noticed last night around 22.20 that the 'Broadband' light was out again. I would appreciate another connection log if you'd be so kind.
Thank you.
aesmith
Fixes: 4
Just referring back to your earlier description of an old style socket and the fact that its not the first "box" on the phone line.  I wonder if it would be worth getting BT to run new cable from the point of entry direct to your socket, fitting a new modern master socket.  Not sure how much that would cost, maybe Plusnet can advise if the phone line is with them.
MasterOfReality
Fixes: 57
Hi @Lynnpin
Here is your Visual Radius for the last 7 days
Thanks,
MoR
