Slow Broadband
offtrolley
Slow Broadband
Only getting 8 down and 9 up
Is there a problem in the Cardiff area?
6 REPLIES 6
Fixes: 385
Re: Slow Broadband
@offtrolley It is most likely just you. What service are you on, and which router are you using?
offtrolley
Re: Slow Broadband
Unlimited Fibre Extra inc. Line rental
Plusnet Hub One
Ran another test
UPLOAD 5.76
DOWNLOAD 7.41
IP location is showing as Sheerness
Fixes: 479
Re: Slow Broadband
@offtrolley
Report a fault using the test bot. See: https://www.plus.net/help/report-a-problem/
Fixes: 385
Re: Slow Broadband
@offtrolley If you have a phone connected, is it silent when you run the Quiet Line Test (17070, option 2)?
offtrolley
Re: Slow Broadband
Unfortunately, I no longer have a phone to test it
offtrolley
Re: Slow Broadband
The REFRESH appears to have resolved the issue.
Thanks everyone for your help
