Shocked slow as snail on my fibre
- Shocked slow as snail on my fibre
- « Previous
- Next »
Re: Shocked slow as snail on my fibre
08-05-2014 10:59 AM
@Andy.
I have run the programme you suggested, not sure if it tells me anything or not.
Here is a PDF version of the report.
Sorry, here is a version with only the parts you mentioned selected.
Message 811 of 815
(526 Views)
08-05-2014 11:18 AM
Try these programs:
http://www.bleepingcomputer.com/download/driver-fusion-driver-sweeper/ ; (checks for outdated drivers - make sure you uncheck the free programs that come with it when installing)
http://secunia.com/vulnerability_scanning/personal/ (Scans and checks all installed programs for updates)
Message 812 of 815
(526 Views)
08-05-2014 12:14 PM
Sussed it!
It was something called "AMD QUICK STREAM" which was installed when I updated my graphics drivers/software at about the time this problem started.
Seems it prioritises your connection for streaming whether you are steaming or not, it is known to cause issues.
Uninstalled it & all is now ok!
http://forums.amd.com/game/messageview.cfm?catid=483&threadid=173554
http://www.shouldiremoveit.com/AMD-Quick-Stream-10102-program.aspx
http://amd-quick-stream.software.informer.com/3.6/
http://www2.ati.com/drivers/AMD_Quick_Stream_2.0_Showcase.pdf
Thanks for help on this & the info is of use for others who might have the same problem.
Message 813 of 815
(526 Views)
09-05-2014 12:22 AM
@buseng Great to see it sorted
Message 814 of 815
(526 Views)
09-05-2014 12:44 AM
Thank you.
Message 815 of 815
(526 Views)
- « Previous
- Next »
