Shocked slow as snail on my fibre
- Shocked slow as snail on my fibre
Re: Shocked slow as snail on my fibre
28-04-2014 9:00 PM
TBB speed test
TBB graph snapshot
Speedtest.net
<a href="http://www.speedtest.net/my-result/3468142407"><img src="http://www.speedtest.net/result/3468142407.png" /></a>
28-04-2014 9:43 PM
Ping statistics for 212.58.246.103:
Packets: Sent = 100, Received = 96, Lost = 4 (4% loss),
Approximate round trip times in milli-seconds:
Minimum = 17ms, Maximum = 25ms, Average = 18ms
I sure hope this isn't a sign of things getting worse, it's kind of getting beyond a joke now, BTW cant say nothing is wrong with results like this. and i'm to believe i'm the only one on my exchange / cab with this problem
28-04-2014 10:07 PM
Try disconnecting/reconnecting and run the ping test again.
28-04-2014 10:24 PM
pings are fine in fact much lower also no packet loss
Ping statistics for 212.58.246.104:
Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Minimum = 13ms, Maximum = 17ms, Average = 14ms
Speed tests back to normal as well Not sure if it was due to the Gateway hop or because around this time Peek time issues start to go back to normal for me, could be a bit of both i don't know,
28-04-2014 10:28 PM
Worth keeping an eye on though.
29-04-2014 2:04 PM
As you may of seen from ticket #81892611 & this thread things haven't been going too well ending with a massive speed drop at the weekend & further more on Monday.
Anyway, regarding the latter after trying many things like rebooting the router & connecting direct to the O/R modem all to no avail I tried one last thing.
I run speedtest from some of my other devices, ie an iPad & a mobile smartphone both via wireless.Lo & behold they gave near normal speeds (remember my BT profile is still 58 instead of the original 73-74) given they were on wireless.
My desktop on Ethernet was still only giving single figures though. I uninstalled the Ethernet adapter via device manager & re-installed it, believe it or not my speed come back up on my desktop!
However that is not the end of it, on turning on my desktop today the same thing happened again. To try & eliminate everything I re-installed the Ethernet drivers, changed Ethernet cables & finally re-connected my HH5 in router mode only whilst still using the O/R modem.
The problem still seems to be there though.
Not sure what is going on here.
29-04-2014 2:16 PM
29-04-2014 2:29 PM
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Users\ping bbc.co.uk
Pinging bbc.co.uk [212.58.246.103] with 32 bytes of data:
Reply from 212.58.246.103: bytes=32 time=23ms TTL=57
Reply from 212.58.246.103: bytes=32 time=11ms TTL=57
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 11ms, Maximum = 23ms, Average = 14ms
C:\Users\>ping google.co.uk
Pinging google.co.uk [173.194.34.152] with 32 bytes of data:
Reply from 173.194.34.152: bytes=32 time=10ms TTL=58
Ping statistics for 173.194.34.152:
Minimum = 10ms, Maximum = 10ms, Average = 10ms
Or this.
C:\Users\>ping bbc.co.uk -n 100
Pinging bbc.co.uk [212.58.244.18] with 32 bytes of data:
Reply from 212.58.244.18: bytes=32 time=31ms TTL=56
Reply from 212.58.244.18: bytes=32 time=11ms TTL=56
Reply from 212.58.244.18: bytes=32 time=10ms TTL=56
Reply from 212.58.244.18: bytes=32 time=9ms TTL=56
Ping statistics for 212.58.244.18:
Minimum = 9ms, Maximum = 31ms, Average = 10ms
29-04-2014 2:52 PM
29-04-2014 4:13 PM
I disabled the Ethernet adapter & plugged in a wireless dongle. Exactly the same thing happens, after a reboot the connection speed drops to low single figures & like the Ethernet adapter I have to uninstall & re-install the wireless adapter as well & then the speeds come somewhere near normal. Something is "spooking" my network connections whichever adapter I use & they all need re-installing before they use full speed.
Any clues please? It all started last Saturday.
29-04-2014 4:28 PM
Have you tried any anti-malware software to see if anything is causing problems?
29-04-2014 4:46 PM
29-04-2014 4:55 PM
Quote from: AndyH Can you check your Event Viewer log? Or recently installed updates?
Thanks for the suggestions.
Can't see much in the event viewer log, also no updates have been installed recently.
I am now running McAfee full scan.
29-04-2014 5:23 PM
Namely the network adapter problem also happens when you change the Ethernet cable from one device to another even without a reboot. Just happened again when I swapped from the HH5 to the P/N router.
29-04-2014 5:42 PM
Is there nothing at all in the event log to suggest what is happening?
