Service status - why no information?
Re: Service status - why no information?
@corringham
I don't need any lectures on how stuff work thanks.
@Anonymous
Primary DNS 212.159.6.9 secondary DNS 212.159.13.50
br1anst0rm
Looks as if this thread has now developed into two separate strands.
One - as originally launched - was the policy question of why Plusnet no longer provided a clear and up to date "service status" notification on their website and elsewhere (most people learned of the recent problem only from other third-party sources).  The answer on that seems to be that this was a PR/marketing decision (misguided) and that - as @dvorak and others have now indicated - it has been referred to Plusnet staff, and queried, before, but this hasn't resulted in any change of policy.
The other more recent strand is the to-and-fro between some members with technical expertise as to whose DNS servers and where failed, and whether they were set up sensibly.  Like many users, I have zero understanding of the detail of what happens under the hood or behind the scenes.  But @Dan_the_Van , @Anonymous and others wouldn't need to be offering their guesses as to what might have gone wrong and why, if Plusnet had published a clear and prompt explanation of the problem and what they did to fix it...
Which brings us back to the original point:  Plusnet needs to be better at notifying, informing and explaining.  QED.
redsox9
Fixes: 4
Quod erat demonstrandum is the final word. Will Plusnet listen?
corringham
Seasoned Champion
Fixes: 23
@Dan_the_Van I wasn't trying to lecture, I was just trying to reinforce your point that both the configured DNS shouldn't go down together. Any ISP's core systems should be resilient.
@redsox9 I think the answer is definitely NO they won't listen.
@br1anst0rm I think you are correct - Plusnet needs to be better
