Serious Speed Problem Tonight !!!!
- Re: Serious Speed Problem Tonight !!!!
29-10-2013 9:33 PM
Ok, I was noticing a few odd speed problems tonight so I decided to run a few speed tests on various speed test sites including bt speed test and I now have a faster upload than my download, I was getting between 72-75mb download and 16-17mb Upload but tonight its under 15mb Down and just under 16mb Up....Brilliant !!!!
Message 1 of 5
(973 Views)
4 REPLIES 4
30-10-2013 8:44 AM
I can see you had a few disconnections last night;
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13831224636718.png"/>
Were they caused by you? You've no capacity issue currently at your exchange.
Message 2 of 5
(523 Views)
30-10-2013 4:21 PM
Yes they were Chris, I was trying different gateways...
adie:quote
adie:quote
Message 3 of 5
(523 Views)
30-10-2013 5:08 PM
We've not seen any issues that I'm aware of, are you speeds back to normal?
Message 4 of 5
(523 Views)
30-10-2013 6:16 PM
They seem to be.....We'll see a bit later on. thanks
adie:quote
adie:quote
Message 5 of 5
(523 Views)
