Sending mail from outside plusnet
- Sending mail from outside plusnet
29-12-2009 2:12 PM
Hi
I have mobile broadband with 3. Can setup IMAP to read mails - is there any way to send via relay.plus.net (IE access via password?)
Message 1 of 5
(1,809 Views)
4 REPLIES 4
Re: Sending mail from outside plusnet
29-12-2009 2:18 PM
As long as you have a subscription account you can use SMTP auth, with the username and password of your main account.
Message 2 of 5
(621 Views)
29-12-2009 2:21 PM
Quote I have mobile broadband with 3. Can setup IMAP to read mails - is there any way to send via relay.plus.net (IE access via password?)
I don't think so. Normally, as you suggested, it is possible to use authenticated smtp via the plusnet server ( relay.plus.net ) when not connected to the PlusNet network, however I believe 3 block port 25 except for connections to their own server smtp-mbb.co.uk. So I'm afraid that when connected to the 3 network you need to use their smtp server to send mail.
An option would be to subscribe to an authenticated smtp service like authsmtp.com who provide servers on different ports http://www.authsmtp.com/faqs/faq-4.html
Message 3 of 5
(621 Views)
29-12-2009 8:02 PM
Thanks both
I'll try the 3 server.
Message 4 of 5
(621 Views)
29-12-2009 8:09 PM
Using three's server I think you'll find it will only accept emails with a three "from" email address. In which case:
(Click the quote header to get to the original topic)
Quote from: MrC Tah-dah.....
OK, just found the following info on t'web which someone winkled out of 3 support.
Change the smtp server to smtp-mbb.three.co.uk as this one doesn't rewrite addresses on the fly in the same way that smtp.three.co.uk does. I assume that smtp.three.co.uk is solely for 3's own email service and that smtp-mbb.three.co.uk is for evryone else (mbb == mobile broadband?). Note: normally email sent through smtp.three.co.uk doesn't get counted against your data allowance; I'm not sure if this is true for smtp-mbb.three.co.uk so you might want to experiment before sending large attachments.
I can now send email from a 3 mobile with the from and reply-to headers set to whatever I want - yippee!
Mike
Message 5 of 5
(621 Views)
