How come so low compared to sync? Contention?
- How come so low compared to sync? Contention?
29-12-2009 4:55 PM
Surely there's not that much contention?
I know it's an 'upto' 8mb service, but i'd have thought i'd get somewhere near what my line is capable of.
I only thought to check as I bought the wife a Wii for Chrimbo, and downloading a simple channel on the Wii shop seemed to take forever.
Re: How come so low compared to sync? Contention?
29-12-2009 5:10 PM
Then go to see what https://portal.plus.net/my.html?action=data_transfer_speed says is you current line speed - it should be the same.
If it isn't ring Plusnet and ask for your current line speed to be set to match your IP Profile (they can do that immediately). Any problems post the results here and one of the Comms team will do it for you.
29-12-2009 5:16 PM
From BT:
Download speedachieved during the test was - 2805 Kbps
Additional Information:
Your DSL Connection Rate :5504 Kbps(DOWN-STREAM), 416 Kbps(UP-STREAM)
IP Profile for your line is - 4000 Kbps
and my latest at mybroadbandspeed is a whopping 1mb. I bet it's ok by midnight though
29-12-2009 5:32 PM
Having the Plusnet Profile higher than BT can cause some minor problems but I wouldn't think it would be as much as you are seeing!
Have you checked your exchange status?
29-12-2009 6:49 PM
Alarm bells ringing in my head, isn't that rather odd?
29-12-2009 7:02 PM
29-12-2009 7:07 PM
29-12-2009 7:20 PM
Quote from: pierre_pierre No thats normal ADSL Synch, gives the 330 upload
Are you sure? Normally 448 like yours isn't it?
29-12-2009 7:29 PM
29-12-2009 7:32 PM
29-12-2009 8:58 PM
I think it stinks of something very strange if it's still the same (or worse)......
29-12-2009 9:29 PM
29-12-2009 9:45 PM
And if it affects uploads significantly then it can mess up download tests as there's always an acknowledgement to every block of data.
Tone graph would be interesting methinks.
